poly body mounts
Discussion in 'General Parts for Sale' started by 1979jimmy350, Aug 9, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Engery Suspension poly body mounts for a 78-80 k-5 new still in the box $60
  2. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  4. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Will this work for a 86?? And does this come with the bolts or anything else?? Let me know I need some SOOON!!
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    What is the part number? I need to know exactly what it comes with.
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i do not know the part number off hand but it comes with poly mounts washers and the other hard ware. It does not come with the bolts though. I will get the part number posted saturady
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, this is what I need:
    The 2 top rubbers (with steel support), 2 bottom rubber donuts, and 2 steel cups for the core support.
    The 2 top rubbers (with steel support), 2 bottom rubber donuts, and 2 steel cups for the mounts behind the front tires.
    The 2 top rubbers (with steel support), 2 bottom rubber donuts, and 2 steel cups for the mounts in front of the rear tires.
    Unless I'm mistaken, all the pieces with the same name are the same.
    So, 6 top rubbers, 6 bottom rubbers, and 6 cups. I think there are two or four more rubbers for the bed but I don't remember.
    Does this sound accurate?
  9. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    they do not come with the bottom cups you are supposed to reuse the orignal. I am selling as a set the way they came i am not going to seperate the mounts
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I asked you what the kit came with, I did not ask you to separate them. I speculated what it came with and told you what I needed at the same time.
  11. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    if you want to wait until saturday i can scan the instructions that show all the parts included to avoid any confusion
  12. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Did you procure pictures?
  13. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    these are still around
