Poly body to frame mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, May 30, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    That is one of the projects I haven't done yet. I know the poly ones would be stronger and last longer, but I will kill myself if they end up sqeaking all the time. Do they make a lot of noise or not??? The Energy Susp ones are what I'm thinking about.
    '73 K5
    Chevy good...Ford bad
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Ive got polly body mounts and mine dont make any noise .The only dif I see is that they will last along time before wearing out.
    All work and no beer makes Frizz a dull boy
  3. Grim-Reaper
    7,385
    Atlanta
    I think there is a Grafite impregnated mount available. Thos should limit the possiblility of noise. Now unless you have a body lift on regular street driving they should not have any real movement so probably be quiet.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  4. '73 K5
    1,763
    Kansas
    Cool. I drive on the street alot, but I'm going to stay away from a body lift at all costs. I'll give Energy a call and see if they make the graphite ones. Thanks.
    '73 K5
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I too have Energy Poly mounts and mine do not squeek. I was told that the black ones are the ones impregneted with graphite, but I was also told that was not true so duno really.....mine have never squeeked and they are black so that is all that really matters[​IMG]
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Sonds good to me :) I use the black ones on the SWB, and the squeek comes from the spring bushings, not the body mounts. Grease lasts about 3 months out in the desert.........creek, squeek, creek....LOL
    <A target="_blank" HREF=http://fwp4x4.coloradok5.com>http://fwp4x4.coloradok5.com</A>
  7. '73 K5
    1,763
    Kansas
    Yea, at least with the spring bushings you can get the ORD greasable ones. Thats what I did.
    '73 K5
  8. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    The set that you are buying, is that a complete set and does it include everything that is needed? Who are you buying them from and how much are you paying? I wanted to get some of those, too as that is the next step in my build up.
  9. '73 K5
    1,763
    Kansas
    I think LMC and Summit both carry Energy Susp. stuff so I was just going to compare the prices and get the cheapest one. If I was to bet, I'd say that LMC would probably be the best place to shop if you need the bolts and spacers and washers, etc.
    '73 K5
  10. dyeager535
    26,979
