Poly Bushing Grease
Discussion in 'The Garage' started by Smitty, Mar 17, 2004.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    What type of grease should we use with our poly bushings? The stuff that came with my lift looks like a silicone base. Unfortunately, I used too much as I put it together or there wasn't enough supplied. /forums/images/graemlins/thinking.gif Anyway, I need to get some more to finish the lift installation.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I bought some greasable poly bushings from ORD and asked them.....they recommeded just using whatever grease I used to grease my chassis so I just used wheel bearing grease when I assembled mine. /forums/images/graemlins/thumb.gif
  3. Storm Trooper
    Nov 24, 2000
    4,640
    I'd recommend Silicone Dielectic compound (SL-4 at carquest)but you can get at any auto store. That's why they give it to you. Regular grease breaks down poly and realy isn't the best for rubber either. Just my $.02 /forums/images/graemlins/grin.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Dielectric grease is way too expensive for this application.
    Regular grease will not break polyurathane down.
    I'd personally just use the best quality synthetic chassis grease you can find.
  5. Storm Trooper
    Nov 24, 2000
    4,640
    Sorry, I only use the best on my K5 /forums/images/graemlins/whistling.gif
    I'm sick of replacing bushings.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How do you get it in there? That part number is for a toothpaste type tube of grease. /forums/images/graemlins/smile.gif It retails around $15 too!!
  7. Storm Trooper
    Nov 24, 2000
    4,640
    I think it will out live the bushings the way I have been going through them (w/grease). Even if I have to pull them apart once a year to relube them it will be worth it if they last.
    /forums/images/graemlins/thinking.gif Maybe with a K5 we should be using KY?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I guess I wouldn't know, I don't own a K5.
    Sounds like a personal problem. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    Hey folks, try regular old Anti-seize. It works great and last longer than anything else I've tried. I was a bit skeptical when I first heard of it but I tried it. So far it's better than the thick sticky grease that came with my swaybar bushings for my Firebird or several different type greases that I've used in the past.
  10. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I'm replacing all my spring bushings this weekend and I was considering using some high nickle content anti-seize to lube them. Since you've had good luck with it I'll give it a shot. The stuff sticks to anything and it doesn't rinse off. It's even hard to get it off your fingers without scrubbing the heck out of them.
    Does anyone know of a reason NOT to use it??
    I'll wait a few months and check them out to make sure they are still intact.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  11. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Haven't found this yet to try it but the guys on the PSD forum I frequent use it and really like it!
    Magic Lube 631. It is made by Aladin Equipment and is for pool equipment. It is a water proof silicone with teflon in it. Supposed to be a white toothpaste consistancy that won't wash off. It is spendy at around 9.00 for 5oz but it works awesome.
    Tim
  12. jess
    jess Registered Member
    Jan 4, 2004
    27
    CT
    How about marine grease? Very sticky and water resistant.
  13. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
  14. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    I ended up using some Lubriplate Special Marine Grease on my sway bar bushings. If I ever get this truck on the road I'll let everyone know how it works...
  15. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I use marine grease on everything /forums/images/graemlins/dunno.gif
