poly motor mounts
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by arq, Apr 6, 2004.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I'm looking for some poly motor mounts for 1st gen. i remember seeing a post a few monts/year ago.
    thanks,
    ARQ.
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I got mine from Summit. These are the ones you need Body mounts
  3. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    Try GMC Pauls. I'm sure he has the motor mounts. /forums/images/graemlins/thumb.gif
  4. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    oops I miss read the post. I thought you wanted body mounts
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I got mine from summit. They are prothane (not energy suspension because they don't make them). Give them a call and they will be able to hook you up. If you want I could post the part # tonight when I get home.
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Triaged,
    part numbers would be great. I'll check and compare the prices.
    thanks guys,
    ARQ.
  7. ljbear
    ljbear Registered Member
    Mar 24, 2004
    92
    Grass Valley, CA
    Brothers sells a poly motor mount, #BBMMUR2. They list it as a big block mount. It's almost identical to the original GM mount, fit great.
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    These are the #'s. T-case mounts are Energy Suspension and motor mounts are Prothane (because ES doesn't make them...I always buy ES otherwise). These are all Summit part #'s but all they do is add the 3 letters in front of the manufactures part # so they should work at other places than summit.
    T-case mounts (C-bushing on the x-member)
    ENS-3-1106G
    T-case side mounts
    ENS-3-1107G
    Engine mounts
    PTP-7-509
    Edit:
    The trans mounts are Black (I think that is what the G at the end stands for) and the motor mounts are red (oops /forums/images/graemlins/mad.gif).
  9. ljbear
    Mar 24, 2004
    92
    Grass Valley, CA
    I'm pretty sure the Brothers engine mounts were Prothane as well.
