Poly mount questions
Discussion in 'The Garage' started by bear76, Feb 20, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    For those that have gone to poly body mounts, did it stiffen your ride? I assume that the poly has less give than rubber so it should keep the body and frame more rigid. Please post your experience.
  2. dyeager535
    26,979
    Didn't notice any difference, except I think the body tended to flex more, since it will follow the frame now.
    Much worse suspension problems IMO are the quad shocks in front, and the fact that the front leaves hit the bumpstops when going over any sort of speedbump or obstacle.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I didn't notice any ride difference. My clutch (mechanical) works much better wheelin' though (the body flexes MUCH less).
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    The only difference was the 1/2" or so that it added. the old mounts were shot.
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the only difference I noticed was that I could get it inspected afterwards. the old ones were shot and or missing.:crazy:
    I like that mine are red and so is my blazer.
  6. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    when you have rotted out stuff and are swaping in body lift or swaping bodys around then its easyer to go poly and never need to fix it again in my opinion.
  7. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    be sure to change out the hardware as well...why upgrade to all the pretty poly stuff when you're just gonna use tired rusted bolts again...
  8. bear76
    Oct 16, 2005
    1,065
    here
    I was going to put in a 1" BL as well, I THINK they come with new bolts. The truck has really good looking mounts for an 83' so I figured this would be the best time to do it, before they get all crusty from the mid-atlantic winters.
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    ORD body lift does come with new bolts, yes. If you are gonna do a BL anyway, its a good time to swap in poly mounts. Can't hurt, and those factory rubber ones are definitely an expendable.
    j
  10. cbbr
    Jul 17, 2004
    14,681
    That's the set I got also - ORD 1" lift and mounts from ORD. Very simple.
  11. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    If you sensitive to engine vibration/harmonics you may notice an increase. The polys transfer vibration easier than the rubber.
    That was my experience. I immediately picked up some rattles in my dash and door panels that were not apparent before.
