Polymaterial Air filter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Aug 21, 2001.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Has anyone ever taken out the polymaterial air filter that sits inside of the normal air filter? (thick steel mesh filter attached to the housing between the carb and for me my K&N) I was thinking that it would let more air in if it was out. Am I right? I know its not smog legal but just wondering...
    KEN
    DANGIT it's not a bronco!
  2. dyeager535
    26,982
    191
    Yes. It's filled with charcoal. Made for evaporating gas. it's held in with some VERY strong adhesive (at least in my case) You will make a mess, but be careful not to dent or bend the air cleaner trying to get it off. Heat from teh bottom would probably melt the adhesive, but you'd have to repaint it.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  3. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Cool... I was wondering what it really did. It makes for one heck of a heavy housing. I will look into pulling it tonight. Thanks for the help.
    KEN
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You live in CA... if you need to get it smogged, then keep it on there or the smog Nazi's will get you...
    How can I miss you if you won't go away? [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>www.chevycagal.homestead.com/steph.html</a>
    &lt;&gt;&lt; 1 Timothy 4:12 &gt;&lt;&gt;
  5. dyeager535
    26,982
    191
    In that case, don't mess with it lol. They actually get that in depth down there to take your air cleaner apart??? (not that I'm doubting, just curious)
    Dorian
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I took mine out with the torch - just a little heat around the bottom and it fell right off.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  7. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Well I used my mammas hair dryer to get it off and it worked:)
    It took about 5 min. and using a nail puller it pried off.
    I put all the air cleaner stuff back on and it runs slightly better.
    We'll see... in the mileage....
  8. dyeager535
    26,982
    191
    Don't think you will see any gains (I didn't) but it can't be helping any, charcoal doesn't just keep absorbing forever : )
    Dorian
  9. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I haven't noticed much the past 2 days that I have taken it out.
    It's a lot liter now! The K&amp;N should do a good job of keeping
    the dirt and other minerals out. It sure took alot of heat to break that silicon. ;#
    Thanks for the info. KEN
