Polymeric Mastic
Discussion in 'Audio' started by daleearnhardt01, May 17, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Im in the process of fixing the floors and then putting new carpet in. I figure while its all apart I might as well put some of this stuff down. How much should I put down? Should I do the quarter panels too? Anything I should know about this stuff. I was thinking of putting it down double thick.
  2. 81sb
    81sb Registered Member
    Sep 26, 2002
    14
    Saskatchewan Canada
    I am assuming this is like dynamat?
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Should I put it in double thick in the front area? Is it worth it or will 1 layer be suffiecent? I want to be able to do the front area, cargo, and inside of the tailgate at the very least.
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    The polymeric is cheap enough that you should be able to do multiple layers....
    I'd be sure you buy enough to cover the entire floor, then do the door panels and wheel well humps. At that point, I'd throw the driver's seat back in and drive around to evaluate if it's quiet enough...if not, do another layer.
    A heat gun and roller will help to make it stick. Also make sure the surfaces are free of grease or oils to get the best adhesion. I've got about 5 sheets of that stuff in my workshop and I'll probably be putting it in the 'Burb to make it even quieter than it already is....
    /forums/images/graemlins/thumb.gif
