polyurethane body mount bushings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dodgedude99, Jun 6, 2004.
  1. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    well i finally got around to installing the new Energy Suspension bushings on my K5 today.
    i think i figured out why it leaned to one side!!!!
    the bushings just crumbled apart when i loosen th bolts on the cab mounts, and one the bed mounts, the previous owner when he replaced the floor and tail pan must of found the same thing, except he substituded HOCKEY PUCKS.
    i still have to go get new bolts since the originals are pretty much rotted down to pencil thickness in the middle.
    should they be GRADE 8 or is GRADE 5 ok?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Grade 5's will be just fine since that what stock is /forums/images/graemlins/thumb.gif
  3. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    sweet, thanks.
    better off asking first then spending the $6 or so per grade 8 bolt.
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    stick with grade 5... its more removable than a rusted grade 8
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I thought the reasoning behind the grade choices where grade 8 bolts will shear where a grade 5 will bend/flex? /forums/images/graemlins/thinking.gif
    What was it someone posted a while back about using grade 8 bolts and everyone said they should use grade 5? Mounting a winch or something /forums/images/graemlins/thinking.gif
  6. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    i just use grade 5 because when its rusted solid you can torch or cut it off
    grade 8 is a bit tougher
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I use grade 8 because I can get them cheap enough and they only have grade 8.
    If I could have grade 5 for the same price I would because this is where you want a softer bolt that could give instead of breaking and like you said easier to take out when rusting.
    /forums/images/graemlins/rotfl.gif
