polyurethane body mounts
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kiley, Jan 18, 2002.
  1. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    What polyurethane body mounts do you guys recommend? I'm not doing a body lift, just replacing the original mounts.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I got a Energy Suspension kit and have no compaints about the quality of the kit. Now I will have a chance to test out their customer service because I lost a mount on my last trip (I am susprised I still have all my teeth after that road). I used 2 nuts (regular and all steel lock nut) on the bolt for the rad. support mount (along with all the rest) and the stupid thing still came loose. I lost the lower washer, sleeve, and lower mount[​IMG]. Now I just need to find some time during the week to call them.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  3. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    I have the Energy Suspension mounts also and I have not had any problems with them. i replaced them only a year ago but so far I don't really notice any wear.
    Jeff
  4. SHINTON
    SHINTON 1/2 ton status
    Dec 26, 2001
    148
    Kernersville, NC
    Have you guys noticed more stiffness or anything when you switched? I have considered this as well, I have not looked at mine but I would guess they are the original rubber.
    Sam
  5. 1972Blazer
    1972Blazer 1/2 ton status
    Jan 2, 2001
    238
    carlsbad, California 92009
    I pulled a body lift and put the energy suspension kit in mine also. The only thing I didnt like about the kit is it doesnt have any body bolts. I spent the good part of 2 days looking for zinc coated, grade 8 bolts and nylon locking nuts and washers. Mine were in for about a years and a half before I started my frame off restoration. When I pulled them out they looked like brand new. All I had to do was wipe them off with WD40. I love mine and would recommend them to everyone!
    1972 Black CST Blazer, 350/415 HP, TH350, NP205, 4" Springs Front/Rear, AGR Variable Ratio Steering, 15X8 Ralley Wheels and 35X12.50 BFG Mud Tires.
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Bought mine from Prothane and bought all new hardware from LMC. I did notice the cab is stiffer and a little more road noise coming from the frame. But I like it.
    <a target="_blank" href=http://community.webshots.com/user/70gmc>My 70 GMC</a>
