pontiac help plugs and wires?
Discussion in 'The Garage' started by obijuan, Sep 22, 2006.
  1. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    where the hell are they, it soulds like ones misfiring something. its really hesitant to go, it sputters and has a rough idle. i dont know where to look for the spark plugs to check if that is in fact it. can somebody here tell me? i know its not a blazer but thats my other car. any help would be appreciated. thanks
  2. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    step 1 : remove 4 bolts holding the 2.4 twin cam cover on.
    step 2 : unplug wire on driverside of cover for the ignition modual.
    step 3 : pull cover basicly stright up.
    step 4 : plugs and cap are not cheep.
    help full hints. : only use the exspencive ac delco plugs. and if the big arss white cover thingy is dirty with like black sutt. replace it. it houses the coils.
  3. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    thanks to "sweetK30" i just replaced the plugs and boots on there and did everything right but it still has the same problem. wtf. its like i didint even do anything. the plugs didnt look all that bad either but were black and sooty. its hard to start and stay on, and with the pedel holding the idle up it runs ok for a second and then bad again what could this be? computer, fuel pump? im at a loss here i need this done by monday
  4. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Look for a broken vacuum hose to the MAP sensor.
