pool prob lem
Discussion in 'The Lounge' started by 84gmcjimmy, Jun 19, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    We lose posession on this house July 15th...but we leave town on the 13th.
    For some reason our pool pump isn't working. And it has to work because the pool was in the agreement for selling the house or something.
    The pump hasnt worked since last year when we shut it down. Since the pump isn't circulating water, the water is GREEN from algae.
    We can blow air through the plumbing of the pool, not A LOT of air both ways, but from the pump to the skimmer basket is is good. But from the skimmer basket to the pump is doesn't blow as much water out.
    The air can compress a lot easier than water, so it's possible the plumbing is squished somewhere or something. I don't have a clue.
    All the pool companies won't come out for a while. What can we do?
    last year we had the same problem, the pump didn't suck. But last year it was fixed after a rental place here brought over a huge compressor.
    Anyway we can find out whats the problem? My mom took the pump down to the pool place and they said it works fine.
    Any suggestions? WE NEED TO get this running soon!
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Can you get one of those things that plumbers use to clean out clogged pipes in a house? I cant think of the name right now, but that might work by breaking up whatever is blocking the pipes.
  3. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    a pipe snake???
  4. zcarczar
    Feb 10, 2002
    2,495
    YES!
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    When you turn it on does it spin?
    Also,how is the filter?If its full of junk,your not gonna get any flow.
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    we tried a pipe snake last year. Pretty neat contraption. But our pipes are too twisty for it to work. It wont go in.
    When we turn it on the water inside the pump thing, where the filter is, it spins. But it doesn't fill up all the way like it should.
  7. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    try kicking it?
    you have a ompresser dont you?
    i would try fishing the line down the pipe as far as you can, then blasting the air on might work:confused::confused::confused:
  8. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    find where it draws from the pool, there should be a screen filter. they get pretty clogged. also look to see if there is one at the pump end. remove them and clean them with the hose. could be your problem
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I don't know if we have a screen filter. I will ask my mom when she gets home. Thanks
  10. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    It can be as simple as an air pocket in the suction side. the pump has to have water enough to prime. If there is a big air pocket on the suction side this will not let it start and will let the pump just set there and spin.
  11. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I just replaced the pump motor on mine. It died at the end of the season last year. However after a few weeks of trying to get the water right I found a major problem. Our sand filter has little "fingers" in the bottom that pump the water through the sand for filtering. Two of them had broke and the circulation plumbing was clogged with sand. I had to break down the filter, clean all the sand out, put new fingers on, fill with new sand and in less than six hours our pool was crystal clear and the water circulation was unblievable.
