Poor electric window performance
Discussion in 'The Garage' started by cuervo, Apr 20, 2004.
  1. cuervo
    cuervo Wears Boob Goggles! Premium Member
    Jan 2, 2004
    3,122
    16
    Sweet Home Alabama!
    Hey all,
    I've got an 87 GMC Jimmy with an eletric rear window. I replaced the motor and cable. I also greased the gears.
    The sad news is once I put the window back together, it doesn't have the power to roll the window up without me pushing up on the window. What gives?
    Any ideas would be a great help at this point.
    -Tim
  2. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    Check volts going to motor, and maybe clean and grease the track.
  3. cuervo
    Jan 2, 2004
    3,122
    16
    Sweet Home Alabama!
    Yeah, I greased the gears and track when I had it apart. I'll have to check the volts going to the motor. I did get up under the truck and check the wires running back to the motor. They all look good but you never know.
    The new motor is one from Advanced Auto. It was $100.00 cheaper then Bill Heard wanted for a new one.
    -Tim
  4. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    It may be the weatherstripping binding it up. Open the tailgate and trip the driver's side latch to defeat the safety switch and while you're supporting the tailgate in the upmost position (without it going into the top) roll up the window using the key switch on the gate. If it rolls up normally then the weatherstripping in the top is causing it to bind. If it still doesn't roll up then it may be the weatherstripping in the gate that's binding it. Remove the inside piece of weatherstripping in gate and see if it moves up easier without it. If it does then you may need new gate weatherstipping.
    One of my door windows was very slow and it ended up being the door shell opening was too small (aftermarket door). I had to pull the sheetmetal out a little and now the window works. So maybe your gate got bent slightly and is piching the window (if that makes sense).
  5. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    I think that first thing to do is to connect the wire directlly to the batterry,that way you can confirm that the poroblem is the wires or the switch.
  6. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    at the risk of sounding like a jerk, can you say multimeter???? /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    grease everything and make sure no binding up in vertical track felts,
    if all checks out good then id say worn motor, common problem in higher mileage rigs, power window motors wear out and get weak, thats all there is to it
    good luck
