Poor Heat
Discussion in 'The Garage' started by daleearnhardt01, Oct 16, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Its starting to get cold again and my heat just isnt what its supposed to be. This all started last winter after I had to replace the radiator. The heat is warm but its not hot enough. Before the new radiator the heat would run you out of the truck, now it doesnt. Average lows here in the dead of winter are around 15 degrees. I might throw in a new t-stat to see if that changes anything but other than that I dunno... /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  2. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Ever back-flushed your heater core?
    Takes about 15 minutes w/ access to a garden hose /forums/images/graemlins/thumb.gif
    Then you'll be in w/ heat. /forums/images/graemlins/woot.gif
    P.S. My g/f mentioned I didn't use enough Graemlins:
    /forums/images/graemlins/ooo.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/pimp1.gif /forums/images/graemlins/crewcab.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/shame.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/screwy.gif
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Backflush as stated.. but be very careful if you take the connections off the heater core, you do not want ot cause a leak by yanking on the hoses. It can loosen the solder at the core itself. If you dont have a 195 t-stat, it may be time to look at getting one for the winter.
    John
  4. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    John
    Should never, ever, never go lower than 195* on a CSB. EVER. /forums/images/graemlins/screwy.gif
  5. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Thanks John, I would imagine it has the 195 in it because of the TBI but ill replace it anyways...
  6. dyeager535
    26,975
    If the t-stat was bad, your whole engine would run cold. Whats the gauge telling you?
  7. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeh its got to be a bad t-stat Dorian cause the dang motor is running cold as crap. Its in the 50's for highs now and today It bairly got midway between the 100* and mid mark. So its not even getting close to 195 on the gauge..Guess I answered my own question.. /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Threw a new t-stat in er and boy now the heat is great...Got to take the hose back off though cause its leaking around the water neck, guess theres some crud or something on it..
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    heats so overrated, though, my will burn you leg if you leave it next to the vent too long /forums/images/graemlins/eek.gif
  10. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    John
    I've run and do run 180* degree stat's and NEVER had a problem.. But thanks for your concern.
    John
