Poor heat
Discussion in '1982-Present GM Diesel' started by JORGE, Feb 9, 2003.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    Hello Friends,
    The heater on my truck doesnt warms well.The air flow is good,but with a poor heat for that cold days.
    I was thinking to change the thermostat.
    Somebody has the same trouble in his truck?
    Thanks!
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Check you antifreeze level and if its full change your thermostat to a 195.
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    See if your heater valve opens all the way. I believe its vacuum operated. Im sure there is someone else that would know better. Maybe post this on the Garage forum.
  4. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    Check to see if your fresh air vent (passenger side) is stuck open. If you have low vacuum that will stay open. I believe the hot/cold lever is actually manual cable and doesnt run off vacuum. Only the zones (floor, vent, defrost) is controlled by vacuum.
