Poor heat
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JORGE, Feb 10, 2003.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    The heater on my truck doesn,t works well.The air flow is good,but the air is not enough warm.
    I was thinking to change the thermostat.
    Any other suggestion?
    Thanks a lot /forums/images/graemlins/wink.gif
  2. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    taht should fix it....what temp does your gauge show u r running?
  3. chevblazk5
    chevblazk5 1/2 ton status Premium Member
    Mar 19, 2002
    257
    Sayreville, NJ
    Get yourself a 195 degree thermostat. I had a same problem in my truck. New thermostat solved my problem.
  4. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Same thing with me. Im in Montana and it was around 7 degrees in 0ctober, and my heat would never get warm enough. So I got a 195 themostat, found out mine was stuck open when I took the old one off. Also to get your heat working quiker, just slip a piece of cardboard infront of your radiator and you're good to go. /forums/images/graemlins/truck.gif
  5. JORGE
    Jan 10, 2001
    213
    The Gauge is in the 100-150 range in winter.The 195º thermostat will be valid for the 6.2 Diesel engine?
    Thanks for the replys.
  6. Phreak480
    Phreak480 Registered Member
    Dec 13, 2002
    36
    dix hills, ny
    I'be got the opposite problem in my 74
    air is plenty warm but damn is that blower slow
    anyone ever get the motor rewound to blow faster?
  7. dyeager535
    26,977
    Just go get an AC fan. They are wound differently. You'll either need to make a filter for the motor vent, or just leave it open and hope for the best. It's not too dusty out here, my dads been running his "open" for years.
