Poor Idle 1990 350 TBI
Discussion in 'The Garage' started by Polaris, Aug 19, 2004.
  1. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    Maybe some of you have run into this before. When my truck is cold, it likes to hang at higher RPM's. One time it nearly stopped idling while I was letting it warm up, then the RPM's came up & it sort of saved itself. When it's warm, it can't seem to idle consistently. It goes from about 500-750RPM and feels a bit rough. It's mostly stock, but I have had a TBI spacer on since last year. This problem started this summer.
    What I've tried so far:
    Spraying brake cleaner near the base of the TBI, suspecting a bad gasket. Didn't change the idle.
    Swapping out MAP sensors.
    Replaced a cracked/rotten vacuum hose.
    Inspected the throttle cables. It does seem that they are not closing all the way when it's cold, hence the hanging at higher RPM's.
    I'm not getting any trouble codes whatsoever.
    Thanks for any advice!
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You might try pulling the IAC assembly off and cleaning it.
    Sometimes the valve gets carboned up and causes idle problems.
    Also pull the EGR valve off and clean it too.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Look for vacuum leaks. TBI base is a good start.
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    I had the same problem with mine, it was the egr valve. it wasn't releasing/contracting correctly. Try tapping on it, or even press it in to see if it comes back out.
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I would assume you probably have cruise control on a '90. Carefully inspect the linkage from the cruise control diaphram and make sure it is not binding. I had various idle problems and it turned out to be the cruise contro.
  6. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    with my 91 sub, it was the throttle position sensor. (forget what miles they're good for??), but it wasn't throwing a code either. If you replace it, i believe you need to install, disconnect batt for 5-10 (to clear computer), key on (NOT STARTED), then depress gas 1-3 times, then start.... (this is from memory, but a search on here may yeild more DETAILED, but the Memory reset is essential to doing it right! The idle/WFO cycle is to reset the throw it has...)
    Found plug wires doing that to me once as well.. would do it on the humid days as well as the wetter mornings!
  7. Polaris
    May 30, 2002
    1,182
    Thanks, guys. I'll try some of this out after work. No cruise control to be concerned with. As an ex-sheriff's patrol vehicle, it's the basic of the basic!
