Poor mans Hi steer??
Discussion in 'The Garage' started by sapper, Jul 23, 2004.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    After talking to Stephen yesterday and finding out that i caint go to hi steer do to 52" springs and zero rates pushing the axle to far foward, has anyone tried to make a spacer that would bolt to the knuckles and raise the hieght of the tie rod???
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    dana 60 or 44/10 bolt? There are 1" spacers for either one. You just have to think about all the stress you are then puting on those longer studs. Longer = leverage and when ALL your steering forces(both the crossover and hy steer) are going through them thats a lot of force.
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Sled Dog, I think Sapper means putting a spacer on the OEM Tie Rod mounting point. And the only reason I coul see that it wouldn't work the same reason why Sled Dof mentioned. You would be putting a lot of stress on a very LONG bolt that won't have any support around it. /forums/images/graemlins/dunno.gif
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'v got 57" fords up front pushing it 5" forward and from what i have found I just need to run a 1" spacer on the arms and a new hole to be drilled on my steering arms. putting the tie rod out front and the drag link behind it.
    *** edit, but mines a 44 *** /forums/images/graemlins/dunno.gif
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea like 55willy said, why can't you put the tie rod behind the axle? it would be hard to find the arms for a d44/10b, or have them custom made, but i think it would work.
  6. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Drill a 3/4" hole and use grade 9 aerospace quality, the one's I'm using are according to shear strength, nearly twice the strength of grade 8 bolts /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    www.pirate4x4.com, ask, behind the axle dana 44/10 bolt hy steer arms are around.
  8. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    this company makes raised steering arms /forums/images/graemlins/woot.gif
    clicky
    i wish i had found them before i bought my flat ones i cant go hi steer because the spring is in the way /forums/images/graemlins/doah.gif
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    dodge knuckles have the tierod mounted 1.5" higher then chev IIRC
  10. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    rather than high steer, since your axle is pushed forward (as is mine) why not run double ended arms and mount your tie rod behind the axle?
  11. sapper
    Jul 11, 2001
    3,052
    NoVa
    thats what mine is a dodge, i thought they looked a little higher than those i had seen, pretty much what gave me the idea, something like another inch or two and it would be up there quite a bit.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    can you post pics of your front axle/suspension
    perhaps you can rear high steer it
    or have the arms made so the tierod slips just under the spring pack rather then over it
  13. sapper
    Jul 11, 2001
    3,052
    NoVa
    This is the only pic i have right now, my suspension is laying on the ground untill i get new bushings /forums/images/graemlins/eek.gif
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You might want to get in touch with Sky Manufacturing. I sent the guy an email asking pretty much the same question, and replied saying that he had arms that would work with the 52's up front. I think (can't really remember) he said his arms swapped the positions of the tie rod and drag link. Send him an email, he replied to mine within a day or two.
    Sky Manufacturing.
  15. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Sky's machine my arm to swap the tie rod and drag link /forums/images/graemlins/peace.gif
