poping noise?? :(
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5'er, Nov 29, 2001.
  1. k5'er
    k5'er Registered Member
    Nov 29, 2001
    92
    PA
    when i turn i get a poping noise if i hit a bump or something. could it be the steering? i dont see any cracks on the frame or the box? @!%* !!
  2. dyeager535
    26,979
    Depending on where its coming from, check the body mounts for tightness..i was getting clunks when turning and/or hitting bumps. Just a loose body bolt.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    I get that same popping sound from the front passenger side ... my problem is the ball joints.
