poping noise?
Discussion in 'The Garage' started by 87sm465np208, Feb 2, 2003.
  1. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    can front leaf springs move around and cause a poping noise? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  2. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    Re: popping noise?
    The only popping noise I've had was when the steering box was loose...and when the frame cracked behind the steering box. The cracks can be hard to see, I never found them until i removed the box and cleaned the frame with a wire wheel.
    I'd look at the area closely and check the steering box bolts...they may just be a little loose.
    You could also check the front shackles. My old stock ones the holes were pretty ovalled...that allowed the spring eye to hit the frame.
    rene
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    when the center pin in my leaf spring busted it made popping sounds everytime i turned in either direction.
  4. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    super, well im getting a 4" lift soon, new front springs, cant wait. ill figure it out. /forums/images/graemlins/thumb.gif
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    let us know, im curious if that was it or not.
  6. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    i dont think it is the center pin, i think it is the front springs moving around in the leaf pack, i could be wrong tho, there is no front thing to keep hte springs from moving side to side in the leaf pack in the front of the spring, ther is one in the rear tho, i figure that might be why /forums/images/graemlins/ignore.gif.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    if they are moving then its the pin, have somone turn the wheel while you hold the spring, if you feel the pop in your hand, then most likely the pin, doesnt matter much you gettin new ones anyway.
