"Popping" from exhaust on 454...
Discussion in 'The Garage' started by fortcollinsram, Aug 11, 2003.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    \"Popping\" from exhaust on 454...
    Well my 454 runs like a raped ape...but there are still some things I am trying to work out...
    Well first off...it is a 1992 454 that is pretty much stock except for FT pistons, GMPP Truck Torque Cam, and Comp Magnum Roller TIP rockers...
    I know it is running a little rich and I *think it may have a very slight exhaust leak..But basically about 60% of the time, when I take it up to about 4000-4500rpm and then shift, it usually pops through the exhaust...It does it MAYBE 40 percent of the time if I do it in Neutral with no load on the engine (just revving it up)...
    I was told that it was probably an exhaust valve that is a little too tight. What are your ideas...I haven't set the valves since I put the heads on when it was on the stand. I just did the std. run to zero lash plus another 1/2 turn...So do you guys think I should run the valves or look else where...it runs great except for the popping...
    Oh timing is set at 4* BTDC, the factory spec...
    Chris
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Re: \"Popping\" from exhaust on 454...
    well whenever poppin occurs at high rpm's i always check timing first. my friend's camaro does it too, and i can almost guarantee it's his problem.
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well I have checked and rechacked the timing...it is solid at 4*...
    I will also clarify that it pops ONLY when I let off the gas and let the rpms drop...I can sustain 4000rpm and it is smooth a a babies azz...it is on the slow down in revs that it pops..
    Oh and it is a TBI
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    what ya got for an exhaust? low backpressure can cause that as well. but i'd say check for an exhaust leak and lash next. but mine does it too- i reallythink it's normal. but mine is low BP, didn't do it before i took off the mufflers.
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Maybe you need a exhaust crossover tube installed. Just a thought.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    also if you screwed up the cam (not saying anything about you mechanical skills) the exhaust valve could still be open when the cylinder is firing. same principle as delayed timing except the problem is elsewhere.
  7. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Thorley Tri-Y's with Dual 3" no cats, flowmaster 50s, exh. crossover before the muffler...I will change the header gaskets and collector gaskets and run the valves....hopefully it takes care of the problem...
    Chris
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sounds stupid, but check your plug wires closely. I had one driving me nuts for the longest and I could never figure out what the hell was going on. It didn't seem like I had a bad wire and it was very intermittant. It would pop out the exhaust only under heavy load under accelleration. I didn't suspect the wires at first because they were new, but one must have found the header.
  9. daimok
    daimok Registered Member
    Jul 18, 2002
    40
    north carolina
    if it does it when you let of the gas it IS a exaust leak. My air cooled vw really pops when it get a exaust leak ( common ). more than likely its near the headers , its sucking oxygen in and reburning fuel.( and your running a bit rich /forums/images/graemlins/thinking.gif) Cant find the leak ? try this trick , pour some trans fluid down the carb - engine will smoke like a dog - i mean kill mosquitos for blocks. if you still dont see the leak while doing this , have friends plug the exaust pipes on and off , it will come out where it is leaking. will help lube your top insides at the same time.
  10. Grim-Reaper
    7,385
    Atlanta
    Chris
    Ok so you got a stock block, crank and rods and nothing else.
    Going out on a limb here I would say it's the cam and it's exhaust duration. Was that cam cut for Fuel injection? The cut used on FI is different then the cut of a cam for a carb. It's proably also playing hell with the TBI. Start by checking your TPS and make sure it has the correct idle setting. If it tells the computer that you have any throttle then it may still be feeding gass on deceleration. That gas is still burning when it's hitting the exhaust.
  11. markd79ta
    markd79ta Newbie
    Aug 12, 2003
    Does that motor have that crazy air injection on the manifolds with the air pump? Anyhow, there is a diverter valve that sometimes goes south. If this valve isn't operating properly, you will get that popping in your exhaust. Sometimes it can get really LOUD too. If you don't have this, go through your exhaust joints again especially before the cats like manifold gaskets, etc.
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I don't think this is related to the popping noise, but ya might want to try bumping the timing to 8* BTDC. My BB ran alot better at 8* then it did at 4*. And remember that 4* spec is for a factory/stock motor. Your's isn't stock. /forums/images/graemlins/thumb.gif
  13. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    It's the Flowmasters that you have on there. Every vehicle that I have ever seen with the 50 series has popped like that after reving and letting off the gas.
  14. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well it is stock block and crank, Eagle ESP rods and Hyper FT pistons with coated skirts.The cam is actually a mild version of the Crane 2030 which is the same cam GM specs for the 454ss which is a TBI motor. I will check the TPS (I have yet to do that...) and fix my exhuast leak and see how it does...
    Chris
  15. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Grim Reaper already said this and I agree, too much overlap with the cam. A wee bit too much on the exhaust side. /forums/images/graemlins/eek.gif
  16. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    yeah, i said that too. . . /forums/images/graemlins/grin.gif
  17. Grim-Reaper
    7,385
    Atlanta
    Chris
    BUT the E-Prom in the 454 SS was set for the cam that's in it.
  18. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I have a 8747 ECM from a 1990 454ss...I know lots of guys wiht this samne cam in their 454ss with no ill effects, except more speeding tickets /forums/images/graemlins/eek.gif I ordered som decent header and collector gaskets..When they come in I will do those and run the valves and see what I come up with...
    Chris
