popping noise in the rear driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueOx, Aug 8, 2000.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    The only lift I have on my K5 is a set of 3" blocks in the rear,just to level it out. Even if i put new u-joints in the driveshaft i still hear a metalic poppind sound coming from rear. Its like the drive shaft is binding of something.
    The u-joints are good though. Anyone got any ideas?
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Is this when you put it into any gear? If so, have a buddy look at it from the side when you put it in gear and see if if the yokes do bind. If it is when you apply throttle it may be your drive line angle is messed up just a bit. You can put shims on the spring pads or if your a welder reweld pads in the angle. the latter is way to complicated. you have to tear the axle down to do it. These are problems I had on mine. I have a 14bolt on mine with stainlessdisks and relocated pads.
  3. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Forgot to explain something. Your blocks could be causing a small axle wrap under throttle so that can be the grind/pop sound you hear. The only other things I can think of are, if you have this condition paired up with improper pinion backlash. This can condition alone without lift blocks wont make a loud pop sound. You can feel the shaft spin till postitivley locks into a gear tooth. You shift to drive..*schunk*. then your in gear. Really take a good look at your yokes.
