Popping noise when I let off the gas
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Dec 23, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    When I step on it to above 2500+ RPM and then let off I hear a pop noise through the exhaust, but not a backfire, just a pop. Also does it when I gradually(sp?) raise the RPM to 2500+ and then let off it pops. What could be causing this?
  2. zrobbinsk5
    zrobbinsk5 Registered Member
    Dec 23, 2000
    45
    Beaumont, Tx (north of houston)
    I had the same thing. Look at your muffler right where the front pipe goes into the muffler. I had a small leak there.
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    My Jimmy used to do this all the time, it was almost embarassing. It turned out to be the mixture on the carb needed to be set. Its the unburnt gases in your exhaust burning.
    I had someone set my idle mixture screws properly and now it doesn't pop through the exhaust anymore.
    Rene
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I have a clank when I let off the gas, mine only does it once untill I stop and start off again. I think something is shifting out of position, but I have looked and looked and looked, and can't find anything.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    My blazer used to rumble all of a sudden when I'd let off the gas. I'd get a few good pops. Midas said they be glad to fix for a couple hundred bucks. Went across the alley to a greasy grungy little shop. Was telling the guy there about it. He said to get my blazer out of Midas and he could fix it for less than a dollar. The vacuum line to the anti kick back was dry and cracked. Just a thought.
    creepin' and crawlin'
    Jim
  6. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Mudfrog.....ever check the converter bolts?
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    mud frog, it could also be something like the t-case shifting. Make sure its bolted down. Mine wasn't...
    90K5
