popping noise while turning
Discussion in 'The Garage' started by bigbadchev84, Jul 31, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok i got a 77' chevy 3/4 ton 4wd with a 4" lift and the raised steering arm, when turning the wheels back and forth you can hear a loud popping noise, i had my brother turning the wheel back and forth and can feel the pop through the back of the leafspring, the u-bolts are tight, what else should i check?
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    sounds like a cracked frame bro, you need to get a repair brace for that. Ord has them i think. What it is, is the frame might be cracked, and its normally the case when you start lifing, etc, the added stress will crack the frame.
  3. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    couple of things...
    Sheared center bolt in the leaf spring,bad bushings,cracked leaf,or frame cracked behind the steering box are common causes of popping noises..rusted ball joints or tie rod ends can 'pop"too....good luck!.. :crazy:
  4. foolhardy
    foolhardy Registered Member
    Sep 16, 2004
    84
    check your drage links my k-5 was doing that for a while un tell it popped out :eek1:
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
  6. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    can you usually tell if it is cracked without removing the box?
  7. 1-bad-burb
    1-bad-burb Registered Member
    Jun 23, 2005
    93
    west virginia
    my 85 3/4 ton suburban with a 6" lift and 4" raised steering arm did the same exact thing, I replaced my ball joints, power steering box, drag link (replaced with 2" drop drag link), spring bushings, added the weld in frame brace, and I checked my tie rod ends which are fine, and replaced a broken center bolt in my left spring, fixed the problem for a while but it started doing it again which realy dissapointed me :mad:
    well I noticed my left front tire was low, so, I filled it to 35 psi AND.... the noise went away :confused: I love my old truck but sometimes it can be a real pain :mad:
  8. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    well the front end was gone through a few months ago, balljoints,wheel bearings, stabilizer, brakes, and tie rods, it usaully only pops at a complete stop turning the wheel back and forth
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    My original incarnation of my 83 did that , stock springs poly bushings . Only while stopped . Don't know which component did it , but my lift kit solved the problem . I reused the draglink , tierods etc . Only replaced springs , ubolts , steering arm and brakehoses . I had no broken centerpins or anything , just wavy springs . :dunno:
  10. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    CRACKED FRAME. Easy fix! Get the weld on brace from ORD it fixed mine and I wheel the crap out of it
  11. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    does anyone have any pics of a cracked frame? do i have to remove the steering box to see if it is cracked? i went and pressure washed it and lokked, but i see no cracks.
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    my does the same thing, but, i think its because I had a power steerin pump commit hiri kiri, and put all its fluid in my left front spring. Then it went and collected a buncha dirt. A temporary fix for me so far, has been to jack it up w/ the hilift off the bumper and let the susp flex, spray a buncha graphite powder in it, and itll be fine for a couple months, then it comes back.
  13. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    My Suburban did this before my lift. It was the spring pack on the driver's side, the lower spring would "pop" side to side at the end from the upper spring. I tried tightening the u-bolts, but they weren't loose. Just watch the front of the spring pack while someone else turns the wheel back and forth. I put grease between the springs to resolve this. You could feel it in the floor board when it did it.
  14. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    You can see a cracked frame just by looking around all the bolts and inside the frame and out all around the box. Mine was a hair line crack about 1 inch long right at the front of the box and it was popping like crazy and I first thought it was the springs but NOPE it was the frame.
  15. mjfoster49
    mjfoster49 Registered Member
    Nov 5, 2003
    95
    Tifton, Georgia
    Mine did that, but It was the center pin on the drivers side leaf spring.
  16. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    mine did the same thing, all new suspension/steering and the dang thing popped while turning. turned out to be a loose bolt on the bumper. just barely loose too. i tightened down all the bumper bolts, and all the bolts on the frame near the bumper. stuff loosens up with a lift.
