Popping noise?
Discussion in 'The Garage' started by k5baby, Dec 2, 2005.
  1. k5baby
    k5baby Registered Member
    Jun 7, 2004
    62
    Prattville, Alabama
    On my 72 K5 when I turn my steering wheel I can hear and feel a popping noise. What could this be? :confused:
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    any joint in the steering system..... tie rod, drag link, tie rod ends for starters
  3. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    Might be the frame is cracked around the steering box :mad:
  4. francis
    francis Registered Member
    Oct 11, 2005
    79
    kemp, texas
    it sounds to me like you have a u-jount out in one of your front axles :crazy: to tell which side it is on see which way you are turning when it happens. if it happens on left and right then you could have some other serious issues or both u-joints out.
  5. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    Go through and make sure all your bolts are tight in the front end.
  6. francis
    Oct 11, 2005
    79
    kemp, texas
    let us know what it was!:laugh:
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Sounds like a front axle ujoint
    I had that happening in my 79 until one day "KAPOW" and no more 4WD. I replaced the front axle ujoints and all was well again.
    Mike
  8. earthad
    earthad Newbie
    Jan 18, 2006
    Southern California
    I have the same thing on mine, when i look at the steering components it looks like the leafs are sliding in and out and making that noise... just some input good luck finding out what it is
  9. mjfoster49
    mjfoster49 Registered Member
    Nov 5, 2003
    95
    Tifton, Georgia
    it did that on mine, and the center pin in the springs had broken
  10. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Check your spring bushings if your springs are moving back and forth. Re torque the u bolts regurally, the come loose eventually if never checked.
  11. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    My vote is u joint. Ask me how I know.
  12. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    What he said, thats my vote if memory serves me .Have a freind or wife or what not turn the wheels from left to right, while your under there checking, find it fast that way.Just make sure you dont owe the person any money, the one in the cab .:D
