Popping noises in 90 Jimmy
Discussion in 'The Garage' started by BigOrange90Jimmy, Aug 12, 2002.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    When I drive my truck, it occasionaly makes an odd popping noise. It's got the stock drivetrain (for now). I figure it's the 241 in it cuz it's the only thing that hasn't been rebuilt, besides the wimpy 10 bolts. It does it in reverse, forwards, and even at 65 mph's. What are your thoughts?
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Check and re-torque your u-bolts and shackle bolts. After that check out your bolts from the x-fercase to cross member.
  3. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    alright i know the u-bolts are tight, but i haven't tried the crossmember bolts. what should they be torqued to?
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Could be the floor. Mine does it, its got cracks where the seats bolt in.
  5. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    good idea, also, check all bushings and especially ball joints, and bearings, jack up front and shake tires by grabbing top and bottom and see if it rocks inwards and outwards, or left to right for checking tierods. if it rocks in and out then have someone watch backside and see if it is bearings or ball joints.
    Rob...
  6. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I know it's not the seats or the ball joints or bearings. It's an extremely LOUD popping noise, like metal breaking. And everything in the front & rear axle is fine. It can't be the tranny, and it can't be the engine. Someone on another post said rivets in the frame, but I have no idea how to check those.
