Popping noises
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Oct 19, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    When I am driving, I can hear a popping noise that seems to be coming from the back springs or something back there. It is usually while going over bumps, and I just went muddin' a fe days ago and it got a lot worse. Any idea what this is? Its really annoying
    90K5
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    check your shock bolts and the bushings in the springs themselves
    DRIVE IT LIKE YOU STOLE IT
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm hoping ita something wrong with the leaf springs because I'm repalcing them on Saturday
    90K5
  4. Heath-La. 89GMC
    Heath-La. 89GMC 1/2 ton status
    Feb 18, 2000
    134
    Monroe, Louisiana
    Check the U-Joints.. just to be sure. They can make all kinds of different noises.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I thought about the U-joints, but I got new ones on about a month ago and it didn't help any then.
    90K5
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Look over your frame very closely and carefully. Use a flashlight. Look all around the rear suspension mounts on the frame. Also, look at the rear bodymounts for signs of wear or damage.
    [​IMG] Semper Maintenance!
  7. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I here the same noises from the front. It started when I took the swaybar off. I have the ORD steering brace, so I don't think its the frame, but I haven't looked yet. Any ideas? Same as for 90k5?
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MT/R, 15x10 Bajas
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Yes check the shock bolts, especially the uppers.
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The shock mounts should be ok too, i just repalced it.
    90K5
