Popping open my 208, any pointers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Apr 10, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have to get that 208 leak fixed this weekend. I plan to drop the 208, pop it open, clean the halves and reseal them, clean the adapter and then reseal everything back up to the tranny (700). I have never tackled a tcase before. Anyone have any pointers for me? Anyone in the Plano TX area interested in helping and/or supervising?
  2. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I just rebuilt mine. Just take your time and remember where things went.. It was pretty straight forward and if you are just resealing the case it should be no problem at all. Get the Haynes manual, they have a great write-up on rebuilding the t-case....
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Don't get scared when 120 roller bearings go everywhere. Just use grease to stick them back in!!!!!!!!!! - Doug
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    If your are leaving the adapter on the tranny and unbolting the t-case from the adapter, you may want some help getting it back in...The felt gasket that seals between the t-case and adapter tears very easily...I used gasket maker to hold the felt gasket on then used my knee to rotate the t-case to line up the bolt holes...Also, pry the halves apart on the bolt tabs, not the mating surfaces where the gasket is, or you may nick the case good and will NEVER seal correctly...Not to bad though...Also, clean off the magnet that is by the drain hole while you are in there...it gets kinda nasty...
    Chris
  5. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    Did mine about 6 months ago.
    If you need any help give me a shout.
    PM me and I'll get back with you.
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I resealed my halves without dropping whole transfer case. Just remove driveshaft, brace bolts, and unbolt the halves, clean add new silicone bead and reasemble the way it came off. Unless your redoing the whole thing.
    Tom
  7. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    I just replaced the entire center section on mine, used Rtv sealant on the adapter/case no gaskets of anykind and its holding without any leaks. I didn't "pry the casings apart used a rubber mallet and just tapped on the them until they separated. If you remove everything from the back of the case moving forward, the bearings will stay put! Good luck
    Rating....2 six pack, Saturday job
    White Knight
    (Christian/redneck/republican) 3 of the best things in life
  8. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Yeah and dont let the magnet win....lol
  9. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    How many miles are on your transfer case if its allot replace the shift fork pads mine just wiped a shift fork out .
