Popping out dents
Discussion in 'The Body Shop' started by hi pinion, Aug 20, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    I have a dent on one of my cars actually,not too big,how hard is it to pop it out????? Is there a way if its not too bad to just pop it out??? Oh, and what about these companys out there that do this paintless dent removal, has anyone used them before??? /forums/images/graemlins/thumb.gif
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    ive never used paintless dent removal, but the best way to pop it out without paint would be to get good access to the back side and gently tapping it out with a dolley or a hunk of metal on the other side.
  3. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    and if the dent is big enough, you can use one of the big suction cups with the handle to pop it out also, ive done that on my dodge after hitting a tree.
    dry ice is supposed to work also. rub the area down with the ice and its supposed to pop back into shape.
    but if the metal is creased, its body work time.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I bought one of those kits-
    It takes a lot of time, patience and practice before those kits are effective.
    Basically, your massaging the metal back into shape. As long as the paint isnt cracked, you can do it. You start from the outer areas, and try to move the tool across the surface, gently pushing until the dent is gone.
    This is really only effective on dents that arent creases- sharp creases, or dents on particuarly thick metal (like pickup truck bedsides) will probably require more serious efforts.
  5. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Bawhahahaha
    I hear that all the time. Don't feel bad I used to think that before I got into the business.
    Where is the dent and what kind of car?
    Michael
    CoOwner: Performance Paintless Inc.
    Mustang, Okla
    Hail damage, door dings, and minor dent repair
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    your probably going to have to shrink the metal in the area too. i've heated up the area and quench it down with ice wraped in a cold wet towel. worked for my 69 rear quarter pannel. you can also use a pin point hammer. it's kinda difficult to know what you are up to without looking at it.
    my 2centavos...
    ARQ.
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hye give me a call is the car at the new house? ill come take a look at it i took autobody in HS
