popping out of 4 wheel
Discussion in 'The Garage' started by mod, Jan 23, 2005.
  1. mod
    mod Newbie
    Jan 23, 2005
    4
    manitoba
    has any one come across there np203 transfer case popping out of four wheel ,but the shifter does not jump out of place ,the problem i'm having is that when i'm in 4x4 it jumps out into 2x4 every 5 to 10 sec then back into 4x4 again and this goes on all the time,so i pulled the t-case apart found the main shaft that holds the upper gear for the chain worn out and the washer completely missing ,so i got a new used one and installed it also with a new chain , but it still has the same problem .every thing else is in good condition .and adjusting my linkage does not help?
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I'd recommend rebuilding it. Buy a full kit and go through the whole case. That's what I did and I've been trouble free since.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    also check your tcase ount on the crossmeber for play
  4. mod
    mod Newbie
    Jan 23, 2005
    4
    manitoba
    thnks for the help
    looks like i'm going to have to or fill it with gravel and run the piss out of it and get another one
  5. Cricket
    Nov 29, 2004
    8,224
    Colorado
    It almost sounds like your gear is walking. Did you make sure the snap rings were all in place, not worn or missing? Was the shift fork in good shape?
  6. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    range fork is bent or the bushings are bad. I am dealing with the same thing on my 208. I have to rebuild it too.
  7. mod
    mod Newbie
    Jan 23, 2005
    4
    manitoba
    thnks
    yes all the snap rings are in place and the fork is good shape ,went to tranny shop they pulled out a fork to show me what it should look like
  8. mod
    mod Newbie
    Jan 23, 2005
    4
    manitoba
    tnks
    fork is in good shape and the range select bushing are good
  9. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    same here.
