popping sound when steering...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyfumes, Jun 3, 2003.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    When pulling in to and out of the garage at low speeds of course something pops up front, it has to do with steering sounds like the drivers side also....what do you guys think, it's a 44 stock except for new springs and HD shackles..... /forums/images/graemlins/confused.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    check out the balljoints and tie rod ends... if they're dry and binding up that could be a cause... also check to make sure everything that locates the axle is tight...
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    At first glance I thought it said "pooping sound when steering" I was like "riiiiiiight" /forums/images/graemlins/rotfl.gif
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Couple of ideas- Frame crack at steering box, loose frame rivets, loose body mounts. Have someone turn the wheel back and forth and see if you can isolate it. Sometimes WD40 works to isolate the noisy area. I had a similar situation, found some rivets bad, drilled em out and put in G8 bolts....HTH
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check the frame for cracks or a loose steering box
  6. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    It's the beer can between your legs /forums/images/graemlins/rotfl.gif Your crunching the can when you turn... Mine makes the same sound /forums/images/graemlins/rotfl.gif
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    yeah its the frame flexing around.
  8. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Mine does it too. It also does it when I hit bumps. I can feel it in the floor boards and hear it. Everything checks out tight and I can't find any cracks in the frame.
  9. Confedneck
    Nov 1, 2002
    5,236
    mebbe theyve got a bent rear 10bolt too? LOL
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you may be right /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    make sure your draglink is lubed properly. mine makes the same POP! when i neglect it.
  13. chevyfumes
    Feb 24, 2000
    38,584
    266
    everything looks to be alright, I think it is just neglect from not lubing ,I ran out and need to get some more grease .... /forums/images/graemlins/thumb.gif
  14. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] Mine is exactly the same way. Feel it in the floorboard, hear it and can't find anything at all loose. Was under there for 30 minutes the other day. It happens when I stomp on the gas and let off too. Like when the front end of the truck picks up and lets down. Not all the time but yeah. Usually when turning to the left not really to the right. I was thinking cracked frame but can't find anything.
  15. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    Jon /forums/images/graemlins/burb.gif
  16. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Mine is the springs moving in the stack.
    Squirt some WD on the pack and I bet you it will go away /forums/images/graemlins/grin.gif
    I actually put my hand around the pack when I was trying to figure mine out - one of the middle springs moves very slightly. I thought 'oh shite' and tightened the u-bolts more but that didn't help. WD40 did. Seems to get worse when grimy and wet like in the rain. If it has been dry for awhile and no WD the pack doesn't move - probably rusted/stuck.
  17. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> A popping noise showed up in mine after the crossover steering went in, turns out the front crossmember is loose so it's shifting at the rivets when I steer and spreading the frame. </font>
  18. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    That's a good one!!! Did it take you long to find?
    And finding these snap-crackle-pops is a 2 person job.
  19. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    WELLLLLLL....??
    Any updates?
  20. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It didn't take long once a fellow club member (ds350) came over so one of us could turn the wheels while the other looked around for it. There's no bumper on the truck right now either, I imagine that when I put the bumper on the noise will reduce signficantly, then when I get the time I'll grind the rivets out and put bolts in. </font>
