popping spring?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by denver75k5, Jun 12, 2001.
  1. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    when I turn the wheel, or accelerate hard, or flex the truck it
    "pops" . When having someone turn the wheel i can feel it mostley in the front drivers side leaf spring.
    If anyone has any idea what this is please let me know.
    e-mail Husky@apexmail.com
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Mine used to do that, it turned out to be the swaybar. Is your rig lifted? And has your bar been dropped? Once I dropped my swaybar to compensate for the lift, It quit doing it.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Sounds like ball joints. Lift the truck and see if you can wiggle the wheel either back and forth or side to side. It would help to have someone do that and you watch and see where the play it.
    <font color=purple>Have you hugged your K5 today?</font color=purple>
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    It would help if YOU FILLED OUT YOUR PROFILE!!
    You would get quicker answers.....
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  5. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    Check the springs to see if they are loose. Mine does that also. If I make sure it is tight it quits for about a day and then comes back.
    All the bolts may need to be loosened and then retightened to get it to sit properly. I'm not sure. Also make sure your bumper mounts are tight along with the braces. They can move also due to frame flex.
    <font color=red>Spirit of 76</font color=red>
  6. denver75k5
    May 15, 2001
    1,017
    Ya, My swaybar is no longer a part of my truck. It's lifted 6"
    the lift is fairly new, including all of the bushings ect.
  7. denver75k5
    May 15, 2001
    1,017
    As for ball joints i guess that could be a cause , some time ago i had to tighten the upper joint ,,,,,REPLACEMENT TIME!!!!!
  8. DERBST
    DERBST Registered Member
    Jan 5, 2001
    15
    Texas
    Denver, it could also be the same problem I currently have a post for. Remove the nut off the front spring hanger to see if the hole is "wallered" out. If the spring bolts losin up over time they begin to wear up and down as the spring flexes up and down causing the hole to enlarge, thus cuasing your popping sound. Good Luck.
  9. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    I found that the rag joint of my steering column was hitting the inner fender well just barely. Every once in a while it would catch and "POP" when it got unhooked.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  10. Grim-Reaper
    7,385
    Atlanta
    Check your steering box and frame. could be a cracked frame poping.
    I have a pop that I was thinking was the spring...nope it's my 203 case thats still fulltime jumping.
    It's not my damn planet monkey boy!
    Grim-Reaper
  11. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Mine started poping after I did the cross over, the second leaf moves around when you turn. No big deal.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  12. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Mine makes that popping, creaking sound also. I decided to ignore it! LOL. I would check your ball joints though and any thing that could be a safety hazard. My theory is body flex.
  13. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    Mine does due to bad body mounts. Give that a look.
    <font color=red>1988 Chevrolet K5 Blazer, Middletown, NJ (07737).</font color=red>
