pops out of 4x
Discussion in 'The Garage' started by mudbog42, Jan 29, 2007.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    My buddy has an 89 K-5 and when off-roading:D and hits a bump it keeps knocking the transfer case back in two wheel:eek1:, does anyone know what could be causing this:(
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    adjust the shift linkage
  3. mudbog42
    Jul 16, 2006
    452
    Florida for now
    How do I adjust it?
  4. readymix
    May 30, 2004
    6,706
    26
    With a few wrenches.
    Just make it longer or shorter as required.
    Also check the engine mounts and trans/x-fer case mount. If they are bad then it could also be happening.
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    x2 what he said.
  6. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    What case is it NP-208?
    What said above is right, except the shift forks within the case are rubber and start to where down making your case jump out of gear.
    Adjust the linkage the best you can as mentioned.
    We used to have to keep our stupid 208 in 4wd with a bungie cord!
  7. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    Had the same problem on my '90. It ended up being those pos auto locking hubs. Replaced them with manual hubs and no problems since. just my .02:D
  8. mudbog42
    Jul 16, 2006
    452
    Florida for now
    this one already has manual hubs so I am going to check the linkage and hopefully it will fix it
  9. WinslowS
    WinslowS 1/2 ton status
    Jun 1, 2006
    265
    Spartanburg, SC
    I have the same problem, but only in 4 hi, and reverse seems to do it more than bumps, I have a 241 and milemarker lockouts.
