POR-15 App question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Panther, Sep 20, 2000.
  1. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hey everybody. Let's say I wanted to put POR-15 on the inside of truck underneath the carpet. First would it be a bad idea? Second, do I have to pull up the paint first and then put it down? Thanks as always.
  2. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Actually I think it is a great idea. I did mine a few months ago. No you dont have to pull up all the old paint, but you will have to prep the paint and metal really well otherwise it wont stick. since I wasnt to concerned with the finish as much as the durability, I use some 80 grit paper. Then clean it really well, and then paint away.. good luck.
    BlazerBoy
    http://generalblueballs.coloradok5.com
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    You don't need to remove the paint to get the por15 to stick but it won't protect the steel correctly unless it's in direct contact with it. At least that's what the directions say...
    Joe
    RIT Mini-Baja http://www.rit.edu/~bajawww
    Team Mudnuts http://www.mudnuts.org
