POR-15 interior (PICS)
Discussion in 'The Garage' started by TX Mudder, Apr 17, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Here are some pics of my POR'd cab. These three are the 56K-friendly images.
    users3.ev1.net/~mattell/frame/smallporpass.jpg
    users3.ev1.net/~mattell/frame/pordriv.jpg
    users3.ev1.net/~mattell/frame/trantunnelpor.jpg
    Just in case ya'll wanted to see..
    -- Mike
  2. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    That's just what mine looked like. Too bad I put the carpet and everything back over it, lol
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I took those pics while I was waiting for the first coat to be almost dry so I could apply the second coat. In the pic it's still somewhat wet.
    When it dries, it will be a little less glossy.
    In the pic of the tranny tunnel, that POR is already dried - I did it a while back.
    That's semi-gloss black, BTW.
    -- Mike
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Wow, how much did that (POR-15) run?
    Did you do it with one gallon?
    How did you prep the body? Did you strip it down to the metal?
    TIA
    TO
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I have previously bought a 6-pack of semi-gloss black, and that is what I used. It's not really that expensive.
    I also used the Marine Clean cleaner and the Metal Ready primer. They are highly recommended for doing the job right.
    The prep was pretty time consuming. I bought two different chemical strippers and still had to use quite a bit of 40 grit sandpaper.
    I took as much of it down to bare metal as possible. POR bonds best to seasoned metal, so I tried to add grooves to it with the coarse grit sandpaper and then let it rust some. You should have seen my neighbor's face. I was spending so much time sanding the inside and then I just let it all rust. LOL, he's a mustang guy he doesn't get it.
    I would like to have spent more time on the prep work so I could be assured of maximum adhesion, but it's one of those projects that you need to finish within in a reasonable amount of time or enthusiasm wanes.
    -- Mike
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Look's good Mike...
  7. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I don't think it's thick enough....lol. Looks like it will hold up well. I wish I had enough floorboard left to por, haha.
