por -15 or rust bullet??
Discussion in 'The Body Shop' started by mrpoorboy, May 20, 2005.
  1. mrpoorboy
    mrpoorboy Registered Member
    Feb 21, 2005
    84
    hillsboro, oregon
    which one is better and which one to get? thanks
  2. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I just bought 4 -1 quart cans of Rust Bullet. One of the main reasons I went with RB is:
    Rust Bullet
    Q: 19. Will Rust Bullet® hold up to ultraviolet rays?
    A: Yes. Rust Bullet® is formulated to block out the harmful rays of the sun.
    POR-15
    WILL THE SUN DESTROY MY POR-15 COATING IF I DON'T TOPCOAT IT?
    No, your POR-15 protection will remain, but the sun will change its appearance cosmetically. That's why we recommend you topcoat it.
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Zero Rust also looks like a good product, as well as Eastwood's line of rust preventative products. I bought some Eastwood to coat the frame of my '05 but haven't done it yet. I'll post how it turns out. IMO there are lots of better products out there than POR-15.
  4. mrpoorboy
    Feb 21, 2005
    84
    hillsboro, oregon
    will roll on, do it yourself bedliner adhere to these type of products?
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Probably if you apply it while it's still tacky. Or if it's dry then just scuff it up with some 120 grit sand paper. I know the POR-15 has a very smooth surface when it's dry, so if you don't scuff it it won't adhere.
  6. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    The durability of the POR 15 that I put on the rear bumper and axles of my Burb has shocked the hell out of me. I brushed it on and it dried smooth like it was sprayed. As already mentioned the gloss finish will become dull without topcoating it.
  7. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
    I have used POR15 too with great success. I painted my floor before putting down the carpet, and when I restored my CJ7 I used it on the frame...good stuff.
  8. basketcase
    basketcase Registered Member
    Apr 30, 2005
    52
    buffalo,ny
    i've been using chassis saver by magnet paints, It is mostly marketed to the haevy duty market, but worked great in the wheelwells and ojn the hitch on my sub. their gloss black stays glossy without topcoats, but can be topcoated if you desire
  9. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    mrpoorboy... I put bedliner (Durabak) over POR-15. In some places I used their Top Coat, in others I just sanded it. Adhering well in both spots.
  10. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    I like Rust bullet I did the entire bed of my blazer and it just seems to bond alot better, It's like it actually is a part of the metal. POR-15 seems a little too rubbery and flexible when it sets up. Plus rust bullet is really durable once it is on.
  11. mrpoorboy
    Feb 21, 2005
    84
    hillsboro, oregon
    well the results are.............
    rust bullet - 2
    por - 15 - 4
    other - 2
    thanks for the input. hopefully i will make the correct decision.
  12. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am running POR-15 on my sliders and bumpers and do not like it. Where I have rubbed a tree or rock it has flaked and you can sit there and peel it off like the old lead paint. It was all ready on them when I bought them but going to strip it down and try Rust Bullet on them and see how it holds up. It is great for protecting the metal, cause its all shiny underneath but durability is lacking or atleast what is on mine is.
  13. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    Where can you get rust bullet? Do you have to order it from the manufacturer, or can you pick it up in a store?
  14. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    click on the ad at the top of the page
