Por-15 vs Rustolium
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5XLR8R, Sep 20, 2000.
  1. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    This may be a no brainer, but whats people's opinions of rustolium....does it really work, or is it just a scam??? Also, has anyone ever used the rust neutralizer by "Mar-Hyde"???? Did it do the job or is it another false promise?
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Rustoleum $3.95 a can. Por 15 $25 and up. I sandblasted my 14FF and painted it with rustoleum it looks good and i have done some major offroading..it still looks good and it was CHEAP!!! Or use the cans of spray on bedliner if you dont want scratches to appear as ofton..my rustoleum finish is chipping a little... but did I mention it was cheap??
  3. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    POR15 converts rust to a hard finish that shouldn't ever come off unless it is painted over dirt, it seals out moisture from the metal so that rust can't form under it agian, it's expensive but if it's done right it should never have to be applied again.
    Dan
    <font color=red>get involved with land issues or lose the land</font color=red>
  4. K5XLR8R
    Aug 22, 2000
    210
    Washington State
    How much dirt is to much to paint over??..Ive blasted the underside with high pressure water at the carwash, but caint get it spot less...is a little minor dirt/dust ok???(for por 15)And what about "mar-hyde" rust converter??? has anyone ever used this stuff..???????
  5. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
  6. mudfanatic
    Feb 18, 2000
    614
    Aloha, Oregon
    It sounds to me like rustoleum, Hammerite you can buy it at Home Depot might be your best bet. The POR stands for paint over rust, I talked with our local distributor and he said that loose rust should be sanded off but that a good surface rust is what Por should be used on so I said that I just had a bunch of parts sandblasted and he said that would be great too just not to wire wheel the areas to be painted because that would leave the surface too smooth for the piant to adhere to.
    Dan
  7. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    spray on prep solvent befor painting and it will ech surface so paint will bond. I have three trucks and no chipping yet!
