por 15 with an air spray gun??
Discussion in 'The Garage' started by **DONOTDELETE**, Dec 25, 2002.
    is there any special way to do this? there are no instructins on the boxes, just to keep it below 30 psi, is there any special cleaning instructions? should i add thinner?
  1. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    do you have marine clean,metalready and the dri filter?
    if you dont have the first 2 dont use its a waste of time and your money!!!!your gonna have to thin it and dont shake it...
  2. i do have plenty of metal ready and marine clean. what should i use to thin it out? i do not have the por 15 solvent...
  3. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I have no idea what to thin POR-15 with. I wanted to ask what T-case you have in your Tahoe.
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I've sprayed POR 15 without thinning....
    Spray one med. to lite coat....let it flash off.....1 hour.
    Then Spray a med. coat over that.
    POR15 Flows extremely well.....
    at first your finish will look lumpy.....but It does flatten out.
    So be careful, It RUNS.
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Thin at 5% ratio. Spray pressure s/b 30 to 35 psi for high gloss and 20 to 25 psi for lower gloss. You must thin with the POR solvent but you can clean up with laquer thinner. You MUST wear a real respriator when spraying this stuff. If you get any on your skin and do not get it off before it dries you will wear it for a week or two. /forums/images/graemlins/eek.gif
