POR-15
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz316, Aug 20, 2001.
  1. Chaz316
    Chaz316 1/2 ton status
    Jul 25, 2001
    224
    Georgia
    Okay this may be a redundant question; Where can I get POR-15 and will the mesh work for holes? Or is it only good for surface rust?
    Does it keep the rust from returning? Can it be sanded and painted to match the rest of the vehicle?
    I only ask because I would rather repair the small holes rather than cut and weld in replcament pieces. First it would be easier on me and second I am hoping it would be less expensive.
    "If it aint broke don't fix it" is like a 4 letter word.
    <a target="_blank" href=http://www.phatboy.alloffroad.com>PhatBoy.AllOffRoad.com </a>
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I can answer one of you questions...buy it here www.geocities.com/baja/5099
  3. Chaz316
    Jul 25, 2001
    224
    Georgia
    Has anyone used it on the exterior and painted over it?
  4. mudpuppy89k5
    mudpuppy89k5 Registered Member
    Nov 3, 2000
    44
    Marietta, Ga
    I don't have any literature with me, but it seems that they sell a paint that is designed to overcoat the rust preventative paint and be a base to be painted over with laquer or enamel. I've used the rust preventative paint and overcoated it with their chassis coat with good results.
    I haven't patched any holes but their web site has a lot of useful info that may answer your other questions. I've e-mailed them questions and usually had a response the next day.
    John Perry
  5. Chaz316
    Jul 25, 2001
    224
    Georgia
    I can't decide if I should go ahead and replace the panels or try to repair them. The interior is only rusted in the corners by the kick panels, near the seem. I will probably just replace them....
  6. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I just got my por-15 and I am going to put it on my rocker panels. I e-mailed them and they said to give it a thin coat, let it dry put on another coat wait until it is tacky ( almost dry)
    and put primer on over it. then sand and paint it. I'm going to do this in a week or so, we will see how it turns out.
    I'm a sheet slitter, I slit sheets, I'm the best sheet slitter, to ever slit a sheet
  7. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    If you guys want ANY questions about this stuff call 1-800-827-6715. I just talked to this lady a little while ago. She rocks!! He answered every question I could throw at her and then some! She also has a "tip sheet" that she can e-mail you that tells you how to apply it and all kinds of good info. CALL HER!
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    ijust saw the mesh used on wakedogs truck so any questions on that could be directed to him. I have painted over POR15 before... you'll need their special primer... it is pretty easy and comes out great. I also like the Puddy... that stuff works excellent!
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    You didn't say where you were in GA, but if its near Atlanta you can get it from Year One and not pay shipping.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <a target="_blank" href=http://www.gmck5.rockcrawler.com>www.gmck5.rockcrawler.com</a>
  10. natman77
    natman77 Registered Member
    Jul 24, 2001
    7
    St Louis
    Don't know how much shipping is, but YearOne is $7 more on the Paint and $9 more on the Blackcoat and Chassiscoat than Quadratec
    email www.quadratec.com
  11. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    I have pics of the por-15 w/ mesh at my site, www.bigredjimmy.iwarp.com
    It worked great, iused to patch some pretty large holes on the gas tank filler cover on the inside, the biggest gole was probably like 3-4 inches in diameter.
  12. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I talked to a guy out of Chicago at Imperial Restorations ........ I got the info from e-mailing the POR web site .......The # in Chicago is 1-800-576-5822 ........ If any of you local Twin Cities guys knows a better place, Please let me know through a PM before I get it from these guys if it will be quicker than 3 days ............ Also, I asked how it would be to go over my rear floor from GM and they said it might not adhere to the blackish primer the floor comes in ..........has anybody else done this with good results or should extra work be done on the floor to make it work ? Any input from you guys would be greatly appreciated ........ One more thing, How much would be enough to cover the frame, the floor and the inner fenders ????
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  13. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Hey Riz, call the number I posted in a couple replies up. Its in California, but its an 800 number. I'm tellin' ya, this lady answered EVERYTHING. She is VERY knowledgable about this product. She says bare metal would be better than the paint on the frame and wheel wells. She said if I'm not going to take them to bare metal, to get some TSP (cleaner you can buy at home depot) and clean it with that and a Scotch Brite pad to clean and scuff it up a little. Like I said I was on the phone with her for a good 30 minutes, really informative about application procedures, how each version of POR-15 is different and so on. Her and her husband sell it and use it all the time. CALL HER RIZ!!![​IMG] Let me know if you do, and tell me what you thought. Late.
  14. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I will for sure ..thanks !
    L8r,
