Por 15
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Jun 30, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Is it possible to apply por 15 to the frame with the body still attached? Or is this more trouble than it's worth? Also should I spend money to put por 15 on the undercarriage(mainly the floorpan) or just get some spray-on rubber coating?
    YEEEEE HAWWWWW[​IMG]
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Hey Corby, I wouldn't think rust would be a huge problem in Austin. POR15 is mainly a rust "stabilizer". It is used to kill the rust you already have......if ya don't have any yet paint should be OK on the frame. Same goes for the floorpan....if you have rust already it needs to be neutralized. POR15 would be great for that. Spray on rubber will help with heat and sound.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  3. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    It had zero rust when we bought, but my brother drove it on the beaches in NC, when he went to college. And when it got back it was covered in rust.
  4. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    POR 15 is great stuff....as far as I can see so far. I like it. It's still a lot of prep work to use POR 15 though. But if you just have the beginings of rust...now is the time before it's too late. ONce you've got it....it goes quick(the metal that is) And if you buy a new truck or one in primo shape.....pleeeaaase undercoat it....that stuff works. My mom's got an 87 van that she bought when it was 2 years old from texas...no rust. She immediately got it undercoated. 13 years old and no rust....she doesn't wash the thing either. I think it's been washed like 10 times in it's life!
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hey Michigan........What exactly do you mean about the prep work? Is it hard or just time-consuming? I'm getting the Blazer painted right now, and the underside needs a bit of TLC. I've heard a lot about the product, but not enough about the actual application.
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Por-15 can be applied directly over rust but will leave a rough finish. Por-15 sells other products were the surface can be preped for more of a smooth finish. Have always used por-15 directly out of the can with no problems. Will be doing my blazer this fall. Just don't get it on your skin and let it dry it takes a while for it to wear off. And wipr off any parts that it gets on that you don't want it on while it is still wet. I think it is well woth the money. t ook me and a buddy about 4 hours doing the underside of my 57 buick floorpans and frame car was not taken apart.Only took off gas tank.
  7. Can Can
    15,552
    136
    So if I'm more concerned about the protection factor than the appearance, there is no need for any special prep procedure? All I'm really concerned about is treating any visible rust on the frame and undercarriage and preventing more from popping up. Can you just apply it with a brush? And do I have to avoid any wiring and brake lines, etc...?
  8. MICHIGAN BLAZER
    296
    yeah, you can apply it with just a brush...that's how I did. what I meant about prep work was it took me a while to do my body...I didn't do my underside. I would take a wire brush a get the big chunkies off. I like POR 15 though. I bought the silver paint....nice a thick and w/the metal flakes in it it really did stiffen up my soft metal and filled in a few pin holes.
    87 Cherokee
    65 IH Scout
  9. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    Yeah it is a great product, I am actually doing the inside and underside of my project this week. The only think POR-15 requires as in prep work, like any other paints, is that the metal is clean of all oil, grease, loose rust, and any other debris. Here is a pic of my frame, I have many more pics guys just have been slacking on getting them scanned. Hope this helps
    BlazerBoy
    http://generalblueballs.coloradok5.com
