  1. sharkman726
    sharkman726 Registered Member
    Apr 20, 2003
    22
    VA.
    Any info on how effective POR 15 is? I decided to look at my floor pans the other day and UGH! Pretty bad. I ordered some replacement pans from LMC and a friend of mine said since I am replacing the pans to just pull out everything and POR 15 the whole bottom in and out. Anyone who has used it got some feeback or any tips on using it. I understand it hardens to a ceramic like substance. Thanks /forums/images/graemlins/k5.gif
  2. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    IMO Por-15 is the big chit! I got some and coated my D60 and 14B before installing them and that stuff is rock hard! I am blown away by it. My friends thought I sprayed it on but they didn't believe I put it on with a brush. It dries and leaves no brush marks. One thing I have noticed, it bonds better to slightly rusty metal than bare. I shaved my 14B and hit it with a grinder to smooth the edges on it and it did not stick as well as to the rest of the housing. I painted a lot of parts with it individually also. Steering box, backing plates, diff covers, knuckles, 14B drums etc.. Just use the gloves like the directions state. It wont come off after it starts to cure. I had it on my hands for a week /forums/images/graemlins/rotfl.gif. It's amazing stuff.
    Clay
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. Bushwhacker
    May 13, 2002
    796
    A buddy of mine also used it on his K5's tub underneath. It looks awesome. /forums/images/graemlins/thumb.gif
    Clay
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Did my frame with it.Excellant stuff that is very durable..............
  5. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    have on protective clothing (gloves, paper mask, long sleeve shirt....) and safety glasses when you use this stuff - if it gets on you, the only thing that will get it off is time. read and follow the directions; its not your standard paint. imo - good stuff...
  6. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ]You got that right.be real careful if you spray it on.use a good resperator.that stuff is wicked
  7. rimfire
    rimfire Newbie
    Oct 10, 2003
    sharkman... What is LMC? I too am in need of a floor pan and also that tunnel thing mounted in the bed that goes around the fuel tube.
  8. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    http://www.lmctruck.com/
    You can do online ordering, but you have to know the numbers out of one of their catalogs. You can request a free catalog on the site (and they'll send you new ones whenever they're printed).
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Well...
    I first used POR15 about 15 years ago...
    I liked it at first...
    But after about 10 years...POR15 will start to FALL OFF!!!
    Of course I heard..."You did something wrong!!!"
    But the FACT of the matter is...
    POR 15 HATES SALT....SUN...and MOISTURE!!!
    I've been using Epoxy primers...and urathane paints...
    to HOLD-UP to the elements...
    The only vehicles STILL look good...with POR15
    have been in the garage...for 15 years... /forums/images/graemlins/smirk.gif
  10. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    THey say if you paint it with por15 you need to topcoat it with chassisblack.this is a topcoat to protect it from uv rays..........................
  11. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Yah....I know....I did!!!
    I spent a fortune on their products... /forums/images/graemlins/mad.gif
    I would rather work with the modern "High Tech" paints...
    They KICK ASS!!! /forums/images/graemlins/thumb.gif
    I just painted a 34'Ford frame...and went Epoxy/Urathane...
    I costs MUCH less...and takes LESS time...and looks and lasts much longer... /forums/images/graemlins/tongue.gif
  12. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Damn and I spent about 280.00 bucks and now you tell me /forums/images/graemlins/frown.gif
  13. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    The floor inside my cab is rust pitted but no holes so I decided to coat it with POR15.I followed the instructions word for word,by winter the rust was comming back through and it was comming off.
  14. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  15. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have POR'd my cab and love the stuff.
    This post made me wonder if my cab will start peeling in 10 years. So I emailed POR tech support and linked this post - here's the reply:
    Answer: If applied correctly it should last indefinitely. The sentence that says por15 hates sun salt and moisture is not entirely true. Sun will make POR15 start to deteriorate over time. We do not hide this fact and recommend covering the POR15 with a top coat if it will be in direct sunlight . Now as far as salt and moisture. Por15 is a moisture cured urethane so it really loves moisture it makes it harder. We have countless amounts of customers that paint the bottom of boats and leave them in water in direct contact with the water and have zero problems. Salt POR15 has no problem with salt we have tests that prove so. Unfortunately some people have bad experiences and of course there will be some. I am sure if we could have talked to this person we would have figured out what went wrong and probably would have helped out with the problem(i.e. maybe send him product or half off or something). Usually there is a slight overlook during the process. After that long of period of time I do not understand how POR15 would start to fall off unless it was in direct sunlight everyday for 10 years and was not top coated then maybe maybe he would be right. We just do not have people that call with that type of problem. I can honestly tell you POR15 is the best product on the market bar none. I know I work for the company but if you follow the directions carefully you will not have any problems guaranteed. Thanks Chris
    So that's what POR has to say. I think POR is still the best stuff out there and this post is the first complaint I've ever heard about it.
    You decide.
  16. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...What did YOU expect him to say???
    "The moisture under the POR15 WILL eventually turn into a BIG ZIT...and when YOU pop-it...YOU'LL find there is NO more metal to RUST!!!!"
    LOL...That sounds like BS!!!
    The Urathane I use has a REAL HARDENER!!!!!
    POR15 is just expensive rust-oleum!!!!
  17. sharkman726
    Apr 20, 2003
    22
    VA.
    Well I went ahead and ordered some and will give it a shot. thanks for the feedback see ya in the mud.
  18. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,090
    489
    Grand Rapids area
    POR 15 only works on metal that is already rusty. Even with their "Marine Clean" and "Metal Prep" the stuff won't stay on smooth new metal.
    I also used some of their POR-PATCH, sanded it and painted over it. 3 months later it was cracked and let moisture through to the metal.
  19. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...Actually bare metal is the BEST method...
    I sandblasted my axles...in 91'...and the POR15
    is NOT flaking..
    The bottom line is...
    YOU paint over RUST...it WILL NEVER SLEEP!!!!
  20. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Mixed feelings here. The first truck I did, it all flaked off. I was told I did it wrong. This time, I got all the instructions, used the Marine Clean and Metal Prep and followed all the instructions. Spent some big bucks on all this stuff. I'm doing the diffs. on another truck as I rebuid them ... hope it works, this stuff is a pain when it starts to peel.
    Eric M.
