POR on Wheels????
Discussion in 'The Garage' started by Rob 85K5, May 8, 2003.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Has anyone used POR on steel rims.
    What were the results?
    I have a quart of POR to use and it would save $100 over buying powder coated wheels.
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    it needs to be the kind that can take sun exposure...i think its the gloss black stuff, or i think it flakes off.
    I'm sure someone will have better imput!
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    /forums/images/graemlins/thumb.gif My wrenching buddy did it and they still look good but you will still need a top coat
  4. alesko
    alesko Registered Member
    Apr 27, 2003
    47
    sw pennsylvania
    I used por on my wheels and then used a can of spray bed liner over top of the por. Only been on about 6 weeks and still looks good so far.
  5. dyeager535
    26,979
    As others have said, the UV will kill POR-15's color if you don't do something about it. I painted my trailer last summer with it, knowing it wasn't "UV color stable", and just did a little touch up a week ago on the trailer.
    The color change is quite dramatic, and I even used semi-flat black. The "new" paint is MUCH "blacker", where the area thats been painted for over a year is more "gray". Seems to be sticking pretty good, but IMO, it's just paint, and it probably won't stick much better than a spray can. Goes on thicker when you brush it, but thats probably the only advantage.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    POR is pretty tough stuff, but you have to clean the wheels off pretty good, then use the metal ready stuff. After a few coats of POR, it is highly recommended to top it off with a non UV - active paint- such as regular spray paint. That way, you have a tough, durable base.
  7. Tuff
    Tuff Registered Member
    Mar 4, 2002
    77
    Columbia, SC
    Where can I buy POR locally or do you have to order it online?
  8. por15-texas
    por15-texas Registered Member
    Apr 25, 2003
    19
    East Texas
    You have to be a AUth. Dealer to sell POR-15 and most retail shops don't sell it. Very few shops if any have it you can walk into unless they happen to be a dealer. And then they are 150-200 miles apart due to POR-15's dealer region rules. Can't have to many dealers in an area. Sooo your pretty much stuck with on-line orders.
    Dave
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have used POR 15 on all my stuff I fabbed - bumpers, rock sliders, ect. I will be using it on my tire carrier I am currently fabbing up. The stuff has worked great, but the key is the prep of the metal. You don't prep the metal correctly and it will peel on you.
    BTW, I recently ordered some from our new POR-15 advertiser and have been impressed with the great customer service so far. I see you are a CK5 member and entitled to the 10% discount from the www.por-texas.com site.
  10. Rob 85K5
    1,487
    Pensacola, Florida
    I ended up going with black Eatons. The 6 lug rim has 4" BS but I wanted 3.5". Only after talking to them, the 8 lug comes in 3.5" BS. SO after all this it was cheaper in the long run to buy from them instead of the bare metal Rockstomper wheels.
