Por15??
Discussion in 'The Garage' started by Tshane, Apr 27, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    Any comments toward por15. I have seen it used on my cousin bronco seem to do an awesome job but just wonder how everyone else feels on it
    /forums/images/graemlins/truck.gif
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    try searching for POR 15- just recently- like probably the 2nd or 3rd page here you'll find 2-3 posts regarding it- also a POR 15 Rep replied to the posts and provided some great info on the product and it's uses etc
    Brandy
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I did my frame with POR. Seems to work fine, its still on there. Its not the best stuff to use where the sun will hit it. It wont hurt it, but it fades real bad. That is unless you buy the POR that is suppoese to be UV resisteant or if you top coat it.
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i JUST came in from "por"'n my k5. I finished the firewall, wheel wells, whole underside (frame,bed). Even got under the gas tank..tough to do without dropping it! I had done half of the truck last month and it looked great. Tough stuff and makes the truck look "newer" when you see the black frame and wheel wells. I would recommend it. I also feel MUCH better about fending off the rust.
  5. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    just a note: where those rubber surgical gloves and long sleeve shirt, safety glasses and a dust mask. I found that this keeps the stuff off of your body for the most part. This stuff is not like paint. It is very hard to remove from skin. I found that some hand cleaner(automotive) and a scrubber pad(dishwashing) work well to remove most of it.
  6. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I use laquer thinner to get it off my hands and other stuff it may drip on. It's a little rough on the hands but it gets the job done quick. Por15 is really sneaky because you'll get one drip on your hands and not notice, then the next thing you know it's all over your hands, tools, and anything else you touch before you realize it's there.
  7. por15-texas
    por15-texas Registered Member
    Apr 25, 2003
    19
    East Texas
    I'll be glad to answer any questions you have on POR-15. Just ask.
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    POR 15 is one of the MOST over-rated paint product out there!!!! /forums/images/graemlins/frown.gif
    I used many gallons of the stuff about 15 years ago...
    I did the whole bottom and frame of my truck....
    WELL...after about 8 years...it started to blister and flake!!!! /forums/images/graemlins/angryfire.gif
    NO....I didn't do ANYTHING wrong!!!!
    I put it over clean bare-metal...
    top-coated it....the whole 9 yards...
    The stuff JUST DOESN'T LAST!!!! /forums/images/graemlins/ignore.gif
    I've been using Epoxy primer...and urathane or enamel....
    If POR15 was as GOOD as epoxy....
    GM, FORD and Dodge would use it!!!! /forums/images/graemlins/grin.gif
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    That's just it, you put it over clean BARE metal. I've found it sticks the best to clean RUSTED metal. We painted on my sandblasted battery tray w/o any of the prep solution and it didn't last more than 2 years.
    If you don't use their metal prep solution it will peel or flake off. Even DuPont's metal conditioner doesn't work as well for POR-15. I know of some that has been on a diff housing w/o a top coat for over 12 years w/o any problems.
    It also seems to prefer to cure in a humid environment. MISF painted the bed of his Scout with it and it got sprinkled on while curing outside in sub 70*f weather. That POR has proven to be the hardest of all the stuff he's painted it on.
  10. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    No they wouldn't. They would use whatever is most cost effective for mass production...including labor times for application and drying time.
    If your gonna use the "if it was better" logic then you would never see a vehicle w/ vinyl seats or cheesy parts, and every vehicle would roll off the production line w/ Willwood or Baer brakes, etc...
    POR-15 is great stuff
  11. por15-texas
    Apr 25, 2003
    19
    East Texas
    Rusted metal give POR-15 something to hold onto. If you have bare or sandplasted metal it has nothing so you need to use the METAL-READY to prep the surface.
    POR-15 also loves a humidity. This is how it cures.
  12. por15-texas
    Apr 25, 2003
    19
    East Texas
    With a 3-4 hour dry time no BIG-3 is going to hold up an assembly line waiting for a coating to dry. Even the paint they use is quick drying. If they coated the wheel wells and floorpans with anything to keep them from rusting and help the car last another 10 years it would hurt sales down the road. The are not going to build a car that is suppose to last 10-15 years. They WANT you to replace it every 3-4 years or at least as soon as your finacing runs out.
  13. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    but can you get it on your Hootus? /forums/images/graemlins/rotfl.gif
  14. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    ok....I painted over RUST...TOO
    It turned into a big blister...
    Then Rotted the metal out!!!! /forums/images/graemlins/frown.gif
    The blasted/treated metal...lasted the best Actually!!!!
    Yah....I used ALL 5 products they provide...
    It's much quicker with epoxy....dry times ARE MUCH QUICKER!!!
    I have some brackets that sat in a box for 11 years...
    those still look good!! /forums/images/graemlins/rolleyes.gif
    I have my front inner-wheels done with epoxy/urathane
    and after 11 years....they still look GOOD!!!
    I'm just posting what has happened to me... /forums/images/graemlins/eek.gif
  15. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL... /forums/images/graemlins/rotfl.gif
    I don't think so!!!!
    They know E-COAT is the BEST!!!!
  16. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    My experience with E-Coat while working at wilwood was less than stellar. We tried it on an R&D project and it did laugh at brake fluid (Something one of the purpose made caliper paint kits didn't do), it didn't suffer handling very well. It was easy to nick or scratch.
    Am I the only one who remembers the "POR-15 & Hootus" episode ? That whole thread was a riot. Talk about it being sneaky......
