Porportioning Valve
Discussion in 'The Garage' started by Don, May 5, 2003.
  1. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    For you Member's running rear disc brake's.
    What type of porportioning valve do You run?
    /forums/images/graemlins/eek.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Valved for disc/disc and brand spanking new. $100
    -- Mike
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Gutted.
  4. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    web page Also the tech section in the bloody knuckle.. /forums/images/graemlins/thumb.gif
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Mike, where did you get that prop valve?
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    O.K. Thank's Guy's! /forums/images/graemlins/grin.gif
  8. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    What is the aplication of that prop valve? On the inlinetube site, they dont list a disc/disc valve for a chevy truck. It does look like the one for a 55-57 chevy.
    Also, where is yours mounted? At the master cylinder, or does it directly replace the factory one?
    Finally, what kind of problems did you have with the fittings sizes on the valve vs. your factory ones?
    TIA
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It's gonna go on a 71 K20, I'm gonna dump the stock, "light switch valve", and then replumb from there.
    It will be mounted just below the master cylinder, on the brace bracket. /forums/images/graemlins/eek.gif
  10. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am running the same one as Mike. It mounts in the same pace as the factory one, It is a direct swap it uses the factory hard line fittings. I have no problems stopping my truck "d44/14ff disk 39.5 boggers"
    Link to the correct prop valve on inline tube
  11. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    On my rear disc setup, I run the line from the front brake section of the master cyl into a tee and then to RH & LH calipers. On the rear I run an adjustable (thumbwheel style) prop valve to the rear calipers. Fantastic setup as it is adjustable for loaded/unloaded performance. You do lose your brake failure light, but the brakes work so well that I no longer care. Just my $.02. Have fun!
  12. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Thank's again Guy's, I'll be putting this Disc/Disc combo together in a couple of week's. /forums/images/graemlins/grin.gif
  13. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    HERE is the link to the truck prop valve. The link you gave is a different part number (looks the same, dunno what the diff would be.)
    Like cegusman said, exact same fitting and exact same dimensions as stocker - 100% easy bolt in. If you have a ORD steering box brace you'll need to remove it for a few minutes so you can change the prop valve out.
    -- Mike
  14. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I did my own rear disc brake conversion on my GMC, and didn't change the proportioning valve. I've driven it on the highway, in town and traffic, and off-raod a fair amount so far, and even stood on the brakes hard a few times. So far, I havent had a rear wheel lock up at all.
    Could the fact that I swapped in a 60 front with bigger brakes be the reason that my braking power is still evenly distributed?
  15. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    That could be the rotor's and caliper's are alot bigger than on the 44.
