port and polish
Discussion in 'The Garage' started by tecton, Mar 12, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    what is it
    why would you do it
    how much does it cost
    lol
    im learning :|
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its where you remove material from your heads in the chambers and ports for better flow )its actually an art getting lost with all this cnc this and cnc that you can buy). You'd do it for better flow from your heads , which gives better performance and efficiency. Cost varies depending on machine shop. Hope this helps /forums/images/graemlins/thumb.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  4. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    From what i have been told is that if you dont have a flow bench (what ever that is) to check, it realy isnt worth your time? What is the opion of everyone? I dont really know! /forums/images/graemlins/burb.gif
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A flow bench is out of most mechanics reach. Most regular machine shops don't even have one. Backyard guys can blend the bowls and relieve the ports (make smooth) buts that about all I'd reccommend in my opinion. /forums/images/graemlins/k5.gif
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Unless it a race engine it is pretty much a waste of money.
    Guys that race want every pony they can get and spend hours and hours like 40+ on a single head.
    They have access to a flow bench to ensure that all ports are the same.
    Tedious and costly.
    For the engines in our rigs port matching the head and intake is usualy about all you would want to do.
    If you start to get wild with a die grinder it can get ugly quick.
    Once you start messing with the chambers you have to CC each one to ensure that all are the same.
    Otherwise you can wind up with different compression ratios between cylinders.
    Port matching is a good way to improve flow, just blend and don't start hoggin them out or you wind up with an anchor.
