porting heads
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Jun 22, 2002.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    does anyone know of a good machine shop that will port my new heads for a good price in Dallas? and how much does it usually cost to port heads?
    phill
  2. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    dont know about where, but as far as price goes, it depends on how much work you really want. could range from about $250 for a small "pocket port" to $800+ for race porting and 5 angle valve job. a lot of variables
  3. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    It really depende. I got really lucky and got mine ported for free. The guy who did mine was teaching a class at a highschool and used these as examples.
    Try to get hooked up with something like that.
  4. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    If you have a dremel,the right bits and a good book you can do it yourself, just put some old valves in the heads so you don't destroy the heads when you slip. Just use light pressure, you want to smooth and polish, not get bigger chambers, that would lower compression.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just do it yourself. The only thing you could really do to screw it up is nick the valve seats. I have ported 2 sets of heads (one aluminum and one iron) and it wasn't that hard...just time consuming.The iron heads are better to start on because it is harder to remove too much material.
    I already had a compressor so I just bought a die grinder from home depot (if you are going to buy one make sure it is front exhaust) and a porting kit from PAW. I think I payed under $60 for all the stuff. If you don't have anyone around that has done it befor it would be a good idea to buy a book like David Visard's "Small Blocks on a Budget" which has I chapter devoted to porting different types of heads.
