POSI/ LOCKER
Discussion in 'The Garage' started by XHitman396, Jul 19, 2002.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    im thinkin about puttin in some lockers/posi in the 87, but not sure, i got 2 10 bolts that will run 33's, but don't want a locker out back because its a daily driver, except them air lockers but from what i hear they cost a pretty penny, so what is a good posi for out back, are they reliable, durable, easy to install. and up front i rekn a quick lok or true trac will do the trick, anything i should know about these brands? but if im in 2wd goin down the street, the locker in front wouldn't have any effect on tire wear or breakage or anything like that until 4wd is engaged right? thanks in advance.
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    locker is not a problem in the front if the hubs arent engaged...you will be fine...
    a good posi unit in the back is an auburn gear posi...my cousin has one in his ifs 90 pickup and it does pretty good...handles all his abuse as well
    Later
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    For 10 bolts and 33" tires I would just go with Power trax lockers
    Less than the price of an ARB you can put the No-Slip posi in the back and The lockrite in the front. They are easy to install. you dont even have to pull out the carrier on 10 bolts.
    I'm running lockrites on the rear on my daly driver/trail rig and like them. They work real well.
    More Info:powertrax.com
