Posi Rear End for a GM 10 Bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82K5_6.5L, Jan 14, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    Hey does anybody know where i can get a posi rear end for a GM 10 bolt for my 82 Blazer?? I've heard these make alot of difference off-road? Is it true?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Please fill out your profile a little so we know where you're from at least. Yes thay make a lot of difference. You can get them from a lot of companies mail order OR from local 4wd stores.
  3. dyeager535
    26,977
    Don't think you can get any better than an Eaton posi. (www.eaton.com)
    Of course, if you asked it a different way, if you plan on wheeling a lot, a posi will let you down, and a locker or welded diff is what you need.
    Assuming you don't need anything stronger than a 10 bolt, you won't need anything better than a posi /forums/images/graemlins/smile.gif
