posi rebuild
Discussion in 'The Garage' started by samiam, Mar 22, 2004.
  1. samiam
    samiam Registered Member
    May 17, 2003
    42
    73 with stock 12 bolt rear. The posi has stopped posi-ing. Is this a shade tree rebuild or what? I have installed a lock-right in the front 44 but never rebuilt a posi unit. Any help would be appriciated. Can't afford a Detroit right now so I'm going cheap!
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    if you put a lockright in the front and where thinking about a detroit in the rear I'd put a lockright in the rear!
    What kind of posi, eaton clutch type or gov-loc?
  3. samiam
    May 17, 2003
    42
    Have no idea which posi..how can you tell? Do you think a Lock right in the rear is a good idea? The front one I can disengage by turning a hub. This K5 spends about 25 to 50% on the pavement. I'm just asking /forums/images/graemlins/dunno.gif
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    1st find out which possi(my geuss is Eaton four spring,
    not Eaton Gov-lock)
    Rebuild with new Carbon Fiber clutch packs, and stronger
    springs. You can do it yourself !
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Prolly not a gov loc. just pull it apart, clean it, put in new clutches and shim it up so its nice and tight, but not too tight!
  6. samiam
    May 17, 2003
    42
    Appriciate all the input.. Guess I'll take it apart and go from there.
