Positive Pinion Shackle Flip
Discussion in 'The Garage' started by Cricket, Jan 20, 2007.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Has anyone else done the DIY flip on a 10 or 12 bolt and ended up with a positive pinion angle.
    My pinion is now nose high. From what I measured with a magnetic angle finder I would need a 14 degree shim to get the pinion nose down and opposite/equal to the t-case output/driveshaft angle.
    14* sounds like an awful lot to me.
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    That sure does sound like a lot; could you maybe get a picture of the pinion along with the installed shackle flip? Maybe a picture of the leaf springs/spring perches as well. I'd like to see what's going on here...
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Wow, when i did mine, it pointed my pinion right at my tcase...ofcourse i have a blazer. Your long wheelbase means less angle, but wow, 14* sure does seem much. Ive never had any problems with the angles being off or pinion being pointed right at the case...
  4. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Either that or I'm reading the angles wrong. I checked again and came up with a little different measurement
    At zero* on the driveline I show a 5* angle on the t-case output and a 7* angle on the pinion output. In order to get the pinion down through the driveshaft centerline I'd have to come down 7* for parallel and another 5* for an equivalent angle.
    Technically the angles are within a few degrees of each other but the pinion is up instead of down.
    These are the best pics I could get in below zero temps at night.
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Are you getting vibes at all, or does it just not "look" right?
  6. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    i had long bed 1/2 ton with 14ff and 5 leaf 52" springs. i did a ord 4" flip and needed 1" block to level truck to front. then pinion was nose high. so i found a tapered 1" block from a 70 3/4 ton gmc rear. but used it backwards to kick pinion down to perfect no vibes.
  7. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    It is okay for your pinion to be up or down around 3 degrees. Any more than that and you'll start getting some bad vibrations from 15-35 mph. My K5 took a 6 degree shim to get it to perfection.
  8. sweetk30
    Nov 1, 2004
    25,528
    527
    unless you have real soft springs and bad axle wrap . than it is much worse.
  9. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    Of course, it just depends on each person's vehicle. It seems that even with a 4" block and 8" springs, I don't get any hints of axle wrap, which surprised me, to say the least. I have my pinion down 3 degrees to compensate for any, should axle wrap arise.
  10. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    When I did my shackle flip I installed 5 leaf 57's form an 85 Bronco. The Bronco had these thick ass cast shims that I installed back wards to correct the angle. I never did check it with an angle finder but it worked out perfect with zero vibration.........
  11. Cricket
    Nov 29, 2004
    8,224
    Colorado
    With 33's and 3.73 gears I'd get an bad oscillation at 60-65mph.
    Now with 35's and 3.73 gears it comes in around 65-70.
    I know the pinion angle has changed with the flip bracket because the springs have been moved down in the rear rotating the pinion up, I'm reading a nose up 7 degree difference between driveshaft and pinion yoke. The pinion is up high enough that I'm worried about gear oil getting to it.
    Guess I'll just have to dink around with shims.
  12. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
  13. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the angle on your pinion and the angle on your t case need to be within 4 degrees of each other.
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    1-2* :whistle:
  15. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Btw i wouldnt worry too much about it getting oil, some guys pint ther pinions way up. If it is that much of a concern you can always add more oil with zero side effects...:D
  16. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
