possbile overheating problem?
Discussion in 'The Garage' started by K30Blazer, May 28, 2005.
  1. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I have a 87 GMC Jimmy fullsize. 350 with 160,000 miles on it. New radiator. Temp gauge is all over the place all the way up to 210, but heater never seems to blow really hot air. Got me thinking that maybe my temp sensor is shot.
    Then again I get a real sweet smell when it gets warm. I open the hood and can't trace the smell.
    Any ideas?
  2. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    You might pressure test the cooling system. Any shop should do this for you for free. If you smell coolant it's coming out somewhere. :confused: I'd probably change the thermostat just for kicks since temp is up and down may be sticking.
  3. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I'm betting it's the heater core leaking.
  4. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    maybe thermostat. i had to change mine yesterday bc of the same reason (stuck open)
  5. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    X2 :thinking:
  6. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I had my heater core go bad before. What a PITA that was to replace. I will go see if there is coolant in the passenger side. Thermostat might be worth checking and I will look into the pressure test.
  7. dyeager535
    26,975
    Heater hoses hooked up wrong will result in no/very low heat as well. That won't result in leaking coolant though!
